Crank Sensor Problem
Old Feb 19, 2007 | 07:13 PM
2002z28ryder's Avatar
Default Crank Sensor Problem
I have a 2001 z28. It keeps throwing a Crank Sensor Code, not allowing the car to crank. Already changed the crank sensor but it still wont crank. PLEASE HELP!
Old Feb 19, 2007 | 07:22 PM
1badjimmy's Avatar
You will probably have to have a crank angle relearn done. I read in a Hayne's manual that any time the crank sensor is disturbed that might have to be done.
Old Feb 19, 2007 | 07:32 PM
2001NBMZ28's Avatar
Agree, look the code/diagnostics up at gearchatter.com thinking it should still turn over though???
Old Feb 19, 2007 | 08:42 PM
AlexLs1's Avatar
I had a problem with a Crank sensor code, look on the passenger side near the header and see if any wires are rubbing against them, I had NON-ceramic coated headers at the time due to that a guy offered me them for virtually nothing. But wires were rubbing it would cause the car to buck........
To solve the problem I got my headers heat coated and wrapped the wiring harness in this heat protectant tape.
A long shot probally, might not be what I was experiencing, but it knocks on thing of your list that it could be. Hope I could help. Good luck !
Old Feb 19, 2007 | 09:06 PM
Yeah, I changed the crank sensor and it is doing the same thing but for some reason it isnt getting any fire and it is still giving the crank sensor code.
Old Feb 21, 2007 | 05:19 PM
z28punk's Avatar
go find someone with a tuner and do a CASE learn.
Old Feb 22, 2007 | 06:05 AM
staringback05's Avatar
sounds like a relearn is needed, with efi live...this takes seconds
