my rather.. SAD ownership story.. and pics of my never ending project
i posted part of this in the camaro section, but i thougt some migth like checking this out here that wouldn see it in the other section,
some of you maybe remember when i first startet talking here last august when i bougth my 98 Z28, M6 car, BONE stock and driven 30k,
i was rather unlucky with it.. on the second day i owned it the clutch went bad and the power steering started to leak, i fixed that and the day after i started driving it the engine spun a bearing, and the passenger side window stoped working, all this in 1k miles,
i was rather pissed having this happening in a realy low milage car that i bougth from man in his 60's that haved babyed it fore the past 6 years,
bu anyhow.. i realy liked the car.. its a realy tigth and unmolested car, manual and rather low on options.. ( i like that)
so my options where: let ex owner take it back, or just fixe the car and making the beast out of it that i wanted..
now.. almost 10 months later i have spent most of my money buying stuff in it and working on it,
so far i have bougth
body:
SS rear spoiler
SS 10spoke wheels
kumho 275/40ZR17 tires
drive train:
LS7 clutch kit
LS2 Flywheel
exhaust:
pacesetter ceramid coated long tubes
non cat Y pipe
SLP loudmouth
engine:
99 block
clevite high performance bearrings
clevite perfect circle piston rings,
all bolts from KATECH (rods headstuds and more)
Durabond performace camshaft bearings
LS2 time gear and chain
LS6 ported oil pump
patriot 226/226. 585 112LSA Cam
Patriot ls6 style stageII heads, 59CC
Patriot gold Extreme series double valve springs
Patriot Roller rocker's
chromemoly pushrods
FAST 90mm intake
NW FAST Throttle body
FAST fuel rails
42lb's Injectors
EGR delete.
i am for sure missing somethign out,
also i am working on soundproofing the car, along with other stuff,
here are some pics of it trough the time i have owned it
here it was when i got it, bone stock from bumbper to bumer, only thing un orginal was the Fugly centerlines
few weeks younger pic's
loudmouth installed
motor=dead
body:
SS rear spoiler
SS 10spoke wheels
drive train:
LS7 clutch kit
LS2 Flywheel
exhaust:
non cat Y pipe
SLP loudmouth
engine:
99 block
LS6 ported oil pump
chromemoly pushrods
FAST 90mm intake
FAST fuel rails
42lb's Injectors
EGR delete.
loudmouth installed
motor=dead
and here are the newest pics, taken on the last week or two, takin the old motor out, putting the new one to geather, and i sanded the undercarrage down, primed it, painted and rust protected,
well you should be over 400 rwhp w/your setup. what CC size eads are you running with the Patriot heads? Im running the exact same heads with 59cc and a Comp 224 and put out 409/388, with a FAST 90/90 and TSP 231/237 im gonna put in over the summer...
Nice write up and glad that you decided to stick it out and keep her.
those are 59cc's my hopes are to get 430ish rwhp with tune,
someone's here are getting over 400 just with cam, so i would be dissapointed with only sligth over it with a fast combo and heads,
You will have id say prob 450-470hp with the stuff you have .. A lil over 400 is a disgrace with heads and cam with fast 90/90 setup will definitely net way over 400 sorry...
The undercarriage is perfect and looks like you are doing everything the right way and not cutting corners .
thanks all,
yeahh i expect to brake the 10bolt soon, its a practical way to look at it(also as a broke man) that when it lets go.. i know the engine works
couple of more pics, here i am tearing down the old ls1, to take things like sensor and more of it for my new motor,
making gaskets,
my new ls7 clutxh
head of..
its better to remember what i took af when.. and where it waS?
here is my new shortblock ready to go in,
making gaskets,
my new ls7 clutxh
head of..
