Bounced off rev limiter, am i screwed? I was racing someone and being new to manual bounced it off the rev limiter before I shifted from 3rd to 4th. It bounced like once or twice before I caught it. It seems to run fine , no funny smells, and no warning lights are on. Are there some other things I should check for to be sure? Could you bend a push-rod or valve by hitting the rev limiter like I did? |
you could. are you on the stock rev limiter? |
You are fine... thats what the rev limiter is for, as long as you didn't sit there at redline bouncing it off for 5 minutes like the hondas do.... |
you should be fine. I was on the rev limiter a bunch of times in my 95k mile 01 camaro. If you miss a shift, that is a different story. And sitting the limiter will cause damage. |
I've hit a few times, you should be fine unless you are doing it every time you drive the car. |
I have only seen one car so far with bent PR and the guy was a total idiot. When I had mine I hit it a few times With no ill effects. |
Like someone said earlier thats what the rev limiter is for. |
It's a rev LIMITER... they aren't going to set it high enough to ensure you destroy your engine, that would be pointless. |
Originally Posted by BrandonDrecksage you should be fine. I was on the rev limiter a bunch of times in my 95k mile 01 camaro. If you miss a shift, that is a different story. And sitting the limiter will cause damage. |
It can definitely hurt it if its hard enough. If you don't hear or feel anything funny don't worry. |
You said you hit it while in winding out third gear? You are most likely fine. The most likely way you would bend a PR is forced overrev (via accidental downshift, and in some cases, you'd be luck to get out with just a bent PR with this) Boucing on the limiter while free-revving (no-load on engine/ in nuetral) Bouncing off the limiter doing a burnout or doughnuts. |
Happens all the time at the track, yes its possible to break stuff but more then likely you are fine |
Originally Posted by RacerScott |
Originally Posted by ZeroFear OMFG WTF!! His VIN should be red flagged by carfax as "warning, previous owner was a dickhead" gotta love the guy after the burnout imitating the rev limiter. :jest: |
Originally Posted by ZeroFear OMFG WTF!! His VIN should be red flagged by carfax as "warning, previous owner was a dickhead" |
wow that guy is an idiot... |
© 2024 MH Sub I, LLC dba Internet Brands
