LS6 Intake Install ????'s
Scammer Alert!
Ok i have been taking my time sanding, and prepping, finally painted my intake navy blue metallic and it looks phenominal, anyways i was going to attempt to install tonight and was wondering if you all would mine dropping me some pointers for installing, any little details to make this easier would be appreciated, i have the directions from ls1 howto but we all know once you get in and do it there are a million other things, thanks for any help you may lend
I tried so hard not to break the oil pressure sending unit.....and broke it anyway. Not a bad idea to have a new one on hand in case. The brake booster hose goes to the back of the intake....the oil sender unit is below/in front of that and from what I understand what usually snags and breaks the sender. I'd try to pull that hose out of the brake booster and then rotate it up and out of the way if possible. Take your time and you should be okay. It's a snap once you get it out. Good luck and enjoy the new power!!
Scammer Alert!
is the oil pressure sensor like a cylinder shaped sensor? it screws into the block at the rear of the intake if so i broke the damned thing...does anyone have a part number also, once you get the intake out i use the front new coolant line i bought and plug the back two correct?
Scammer Alert!
also if my ls6 intake has the ridges ground off, do i need to change any of the coolant lines, and do i need to use the plugs for the rear coolant lines, or do i keep all the lines under the intake?
Scammer Alert!
how much was the oil pressure sending sensor? i just wanna thank you man, i was really pissed when all this happened, now im feeling kinda confident when i hit it again tomorrow, when you did it was it a noticeable mod? and if so where did you notice the power down low or high in the powerband
It could be diff in your area, but since i work at a shop, i get the net price discount.
net= $28.63
list= $40.90
I felt it higher in the powerband, but I wasn't that impressed w/ the difference. Not that noticeable to me. Headers seemed better. Every bit helps though
remember, put the last 4 intake bolts on the back of the intake in before you put the intake under the cowl, otherwise, you won't get them in after......
Glad I could help. If you need any more help, let me know. I gotta go get some sleep or i will be dead at work tomorrow..
net= $28.63
list= $40.90
Scammer Alert!
awesome guys i am going to hit it hard after work tomorrow and see how it goes, i was hoping the gain would be noticeable, but alot of people are saying otherwise
just make sure that u use ur stock bolts cause the ones u will get with the manifold are never as good and quite a bit weaker
i make that mistake and broke one in half but if u do break one and it is inthe hole just go to a a home depot or a lows and get something called like a reverse screw i think
