hay guys very quick question about injectors
1 Post
hi guys i am gonna buy some injectors for my 99, as you guys know the 99's came with 26lb injectors, if i get the 28lb off of an 01 camaro ss wilol it fit perfect with no modifications and will i need to reprogram the pcm, will i also see any power gains thanks guys
Yes, Yes, No
They should fit fine, going from 26 to 28 isnt a lot, but probably enough for it to run richer warranting a quick adjustment of the IFR tables, and no you wont see/feel any power gains.
pretty much, if your actually do NEED to upgrade injectors (your 26lbers cant keep up with all the air your moving in) you def. might as well go with something bigger than 28s, 42s seem to fit for most
