LS1 TPI convered to TBI??
Old 11-01-2007, 09:15 PM
andy89's Avatar
Default LS1 TPI convered to TBI??
hey guys new to the LS1 world and was wondering about dropping and ls1 longblock into my 89 gmc truck with my stock intake manifold on it, can i put a dissy into this motor with a conversion intake manifold?? the only reason i want to do the swap with TBI is so i can keep my stoc wiring and the motor i cn get a deal on has no wiring. ust a thought let me know if its stupid
Old 11-01-2007, 09:21 PM
Rebel 92's Avatar
Yes it could be done, There is a way of using a Ford distributor, the part made to adapt the distributor to the LS1 is in the GM performance parts catalog. It could be used with a carb. manifold for the LS1. I would just use a carb before I would try to use TBI though.
Old 11-01-2007, 09:42 PM
Pro52R's Avatar
Originally Posted by andy89
hey guys new to the LS1 world and was wondering about dropping and ls1 longblock into my 89 gmc truck with my stock intake manifold on it, can i put a into this motor with a conversion intake manifold?? the only reason i want to do the swap with TBI is so i can keep my stoc wiring and the motor i cn get a deal on has no wiring. ust a thought let me know if its stupid
1st and foremost your intake WILL NOT fit on that engine.
2nd TBI is junk
3rd That DISTRIBUTOR isn't the most ideal set-up...Keep the factory.
4th You can get a set-up from Edlebrock,etc that comes w/ an Intake and Ignition control
5th It sounds like your trying to pinch pennies. You should just keep your SBC and mod that.
6th LS1 is not TPI...it is MPI
7th Please reframe from using slang. (aka dissy)...Its a Distributor
Also..jsut keep in kind the LS1 may be a small block,but it is totally diffrent from the Gen 1 and 2 SBC's
Your best bet may be to find a COMPLETE 5.3 out of a 1/2 silverado,etc. Then just get a custom harnes..That way you have a great engine,and better EFI. PLus you can find the 5.3's pretty cheap compared to LS1's
Old 11-01-2007, 09:43 PM
Deranged Rat Fink
badjuju342's Avatar
Absolutely NOTHING is the same on your stock TBI and the LS1 . Yes you could make it work but it will cost you more than it could ever possibly be worth .........
Old 11-02-2007, 07:14 PM
andy89's Avatar
hey guys sorry bout the newby post. i got my words and forums mixed up i was meaning to talk about LT1.
Old 11-02-2007, 07:43 PM
Pro52R's Avatar
Ehh...The LT1 isn't anything spectacular or advanced like the LS1...
Like I mention before..keep your engine and mod it.. Cam,headers,maybe a carb instead of TBI (more tuning,etc)
Old 11-02-2007, 08:00 PM
andy89's Avatar
my motor is toasted there is no saving it, 320,000km burning oil and collant. the only reason for wanting to do this swap is i can get a better deal on a lt1 with aluminum head then a stock 350tbi motor, so my questioin remains the same, can a DISTRIBUTOR be put into one of these motors??
Old 11-02-2007, 10:35 PM
SladeX's Avatar
lt1 and ls1 blocks have no provisions to have a distributor. With the LT1, they went to the optispark and the ls1 block uses a cam sensor. The only reason LT1 intakes can be used on gen1 engine blocks is because the area where the distributor is can be drilled out to accept one.
Old 11-05-2007, 05:27 AM
bww3588's Avatar
actully its SFI......
Old 11-05-2007, 05:58 AM
Omec's Avatar
TBI im more of a fuel injection guy, but id take a carb over that any day!
Old 11-21-2007, 05:30 PM
1BadAction's Avatar
I'll stab myself in the eye before I have a vehicle with a distributor on the front
Old 11-22-2007, 09:55 PM
azceta's Avatar
Nope not right you can have a dist on a LT1. Just drill out the intake, switch timing covers. Ditch the opti like a used rubber
Old 11-23-2007, 12:36 PM
WS6NIGHTMARE's Avatar
Bottom line, if youre going to undertake this swap, half assing it and putting in old parts is going to be WAY more hassle than its worth, and will drive up the cost.
Old 11-23-2007, 12:44 PM
3rdgentug's Avatar
theres alot of stuff that has to be converted to use the lt1 in any intake form into that truck. its a bigger deal then i think you think it is.
imo id get the cheaper 350sbc and run it. easy swap not much involved and not alot of conversion headaches. if your dead set on the lt1 start doing your research now, save up get all the parts ready and then when everythings ready do a conversion. that way youve had your truck up n running and wont run into 5$ parts issues that keep you going down the road.
trust me i had an lt1 in my s10 i know what im talking about but.....
just my .02 cents worth
Quick Reply: LS1 TPI convered to TBI??
