Gto Will Not Go Into Gear
i have an 04 gto and my clutch slowly went soft all the way down and wont go into gear.. anyone ever get this problem?? best way to fix? thanks a lot
best way to fix it, probly buy a new clutch? the tranny wont want to let you put it in gear if the clutch is still engaged. Do you have an aftermarket clutch or hydro's? try putting it in first before you fire it, if the car moves/stalls while the pedal is down then its not disengaging. could be your slave cyl.
Your shift linkage could be messed up. My friend had an 04 with 600 miles on it. About 6 full throttle clutch drops later he found himself getting a tow to the dealer.
OWN3D BY MY PROF!
Sounds like a slave cylinder issue to me. I had that happen in my old eclipse GST. With the car off I could change the gears, but when I started it no way. If I left it in gear when I tried to start it instead of neutral it would start driving off like it was automatic.
