headers tune?
headers tune?
ok i've already had my car tuned when i did exhoust and what not but now i'm think'n of get'n some headers. will i need to get a tune after i install them??
How helpful!! THis is how post counts become so high. Is a tune necessary after LT's? No. I, like many would recommend getting it tuned if you want max performance out of them and dont plan on adding any major components to the car soon, otherwise you could be wasting money!!! Good luck in your decision
in your original tune did you adjust the air / fuel ratio? if you did you'll be ok. if not you'll probably be running lean and not getting the max from your mod. A/F should be in the range of 12.6 :1 and 13.0:1. mine is actually at 13.1:1
Try trolling somewhere other than the newbie tech forum if you want to post that without giving some advice as well.
If you had your rear O2's programmed out with your first tune, then I would say no need. You shouldn't throw a lean code or anything. The lean code would be problematic and would need to be fixed as it would be dumping way too much fuel to try and compensate. When you do heads, cam, converter, or decide you want that extra little bit optimized, then it's time to get the tune. If you plan on doing a lot of things a little at a time, I'd recommend getting your own tuning suite, not handheld, and a wideband. It'll save you money in the long run, and in my opinion, you'll be more satisfied with your vehicle overall. Happy modding.
It won't set the lean code. If it is, then there's something else you should be looking at. However, if you don't !cats !air !egr in the computer and you install race longtubes, you're going to throw codes.
