Camaro SS Cam Help
Camaro SS Cam Help
Hello, my son has a 2000 Camaro SS and is doing some mods to it. He already has LT's, Catted Y-Pipe, LM1, SLP Intake, Port TB, and is now going to put in a cam. He is planning on going with the Comp Cams XR265HR Cam. First of all, has anyone had any expirience with that cam, and if so, how did you like it and would you recommend it. Also, is he going to have to do any modifications to go along with the cam, so that it will run right. Thanks.
it is a "decent" upgrade from stock, at 522/.529 lift you could keep your stock springs, but i would go ahead and upgrade to ls6 springs, only $50...if you wanted to, you could compliment the cam with a ls6 intake...you are going to get a decent increase in the midrange...it is perfectly fine for d/d and tuning idle won't be hard at all
Location: The dirty taint of the country. ...Los Angeles
My personal opinion,... Think about how he drives! I can't stand it when people buy "mail order" Cams. Its super general! Plus,.. all newbs go for the LARGEST cam right off the bat. Its super funny when they hit the track or romp on the throttle on the street and spin a baring and throw a rod. Thats when your son ends up taking out dates while using the bus as general transportation for over a month. Things you or he needs to consider is 'how does he drives',... what are his future plans' I.E. . forced induction or naturally-aspirated , Stroker and etc., How many miles does the motor already have on the odomiter...blah blah blah ..blah............bbllaahh!
Thats my piece!!!
If anything else,.. just be advised,... That Cam is considered an upgrade from the LS6 cam w/ a high lift. SOO... basic rule of thumb,.. if it has a lift higher than .600 then your son is gonna need new springs... PERIOD!!! I'd go with Double Valves Springs because they accomidate up to .650 lift. He can use the stock retainers if he chooses to but if he doesn't then he's gonna need new Valve Locks aswell. NOW lets say that the lift is below .600 then he can still use his stock Single Valve Springs.....UNLESS the motor already has an *** load of miles on it. If it does then I would say that he should buy some NEW Single Valve Sprigs just *** a procautionary investment. ... If he does that then he can also reuse the STOCK retainers and locks.
Thats my piece!!!
Thats my piece!!!
Thats my piece!!!
my son doesnt screw around too bad. He'll do the occasional burnout here or there but thats it. He doesnt take it to the track. And his plans for the car is just mainly a N/A build with around 450hp. And also the car has around 65,000 miles on the clock. So, the lift for that cam is .529 so he shouldn't need to upgrade anything right? I think he decided on going with the LS6 springs anyway.
I don't think 450 rwhp is realistic with that cam. And I think 360 cam only is optimistic.
I had ported Ls6 heads, LS6 intake, more lift/duration, & full higher ratio roller rockers & I hit 360 rwhp with a decent tune. I may hit 390 since I put headers, exhaust, & a better tune in it.
Don't mess with single valve springs. Go ahead and buy duals. Patriot golds are an inexpensive 'kit' that gives you the insurance of a 2nd spring if you snap one (around $250). You're also probably going to want to upgrade pushrods to a hardened version. You may need a slightly longer pushrod because the base circle of the aftermarket cam will probably be smaller than the oem. A pushrod length checker is cheap & accurate methodology.
Other than that be sure your son knows that this specific cam is perfect for the car. Once it is installed, it will be a PITA if you have to install a new cam or have someone else install a new cam.
If I was your son, I would check out some cars and car shows (if there are LS1 Camaros/Firebirds prevalent in your area) and make sure you hear the cam in person or possibly ride in the car to test drivability. That may not be an option at this time of the year though.
I was thinking about a cam job once...
with this cam you arn't going to see 450rwhp unless you are using a blower, i agree with the dual springs tho but for the lift of this cam ls6 springs will work fine and they are at damn good pricing
That cam is not big enough to bother changing...to begin with he will never get any place close to 450 rwhp with one that small unless he goes to NOS...get something with duration in the mid to high 220s at least and lift in the high .500s ( like .581, .588, .595, ect.) a number of supporting vendors on here have packages (cam, springs, retainers, pushrods) that will be needed on any can swap/valve train upgrade. A good tune will be nessary for the car to run right. Go for it..
Good luck.
450 RWHP will incite more than the occasional burnout..
Thats my piece!!!
Thats my piece!!!
go big or go home.... i went with a 236/242 605 610 112 lsa with stock 241 castings with comp cam 921b double valve springs so far so good and ive been rompin for about a year with no problems with the stock pistons and soo forth... I put down 400rwhp threw a dana60 and a vig 3800 stall sooo anyway its my dd also... puts down 550 rwhp on a 125 dry shot... u name it ive changed it oh and dont forget to swap the timing chain i went with a double for added assurense.
that cam is way too small to justify all the hassle of swapping it out. go with at least a .580 lift cam and around 226-230 duration. anything smaller IMO just insnt worth the work it takes to swap it out. regardless of what you pick, swap out the springs and pushrods. if the cam is under .600 lift, comp 918s are good. anything over .600 lift, go with a dual spring like the patriots of the comp 921s. drop some chromoly 7.4 length
(stock length) pushrods and you're good to go.
its also a good idea to replace to timing chain with an LS2 chain (i didnt but most recommend it while youre in there for added strength). find a local tuner to tune it with HP Tuners and itll have stock manners with a nice lope and a good jump in power. good luck with it man!
I have read all of the replies and no one has aswered his original question of whos running the cam and how do they like it. Can someone add anyone who is running Comps XR265HR 115 add any input.
Thanks
Thanks
