Electric Cut Out
Old 01-13-2008, 10:04 PM
araber89's Avatar
Location: Holmes County (thats right Amish Country), OHIO
Default Electric Cut Out
I was wondering what a good Electric Cut Out would cost me plus an install. I have the few mods listed below and I think it would be fun to have to cut outs. Any help would be appreciated.
Thanks
AR
Old 01-13-2008, 10:15 PM
Unleash's Avatar
You could install yourself fairly easy. I did.
Here is one at summit for $151.95.
Old 01-13-2008, 10:22 PM
araber89's Avatar
What does it take to install them?
Old 01-14-2008, 05:17 AM
waldershrek's Avatar
Cut a section of pipe out where you want to put the cut out, put slide the cutout over each side and weld or clamp it down. Then run your wiring and you're done.
Old 01-14-2008, 11:03 AM
PewterScreaminMach's Avatar
Thanks
AR
You say cutout and cutouts. I am assuming you only want one.
Do exactly this, haha. There are probably a few detailed threads on how to install that will give wire "routing" tips and cutting/clamping tips if you search. Good luck!
Old 01-14-2008, 03:39 PM
RedRallyeZ's Avatar
installing the "electric" part of the cutout isnt that bad either. It took me probably 2 hours going slow and hiding hte wires, just know where you want to put your switches and indicators ahead of time. and use the rubber plugs on the bottom of hte floorboard to run your wires up through. easy
Old 01-14-2008, 06:14 PM
Midnight02's Avatar
I spent roughly $175 on the electric QTP cutout and around $140 for the install. Well worth every penny!
Old 01-14-2008, 09:11 PM
g-ryde1's Avatar
I have a DMH on mine no problems whatsoever heres some tips on the install
https://ls1tech.com/forums/showthrea...ut#post8390450
