Anybody knows what this hose is called??
Yeah its got a little hole underneath and need to replace. That hose goes behind the motor. It makes my car idle weird and exhaust makes popping noises.
I put tape to cover it and seem to work for now but need to replace.
That piece that has the hole is removeable. It disconnects from the PCV valve right there and from the intake. Mine just got a hole in it too. I just took some normal vacuum line and hooked between the PCV valve and the intake and used a couple hose clamps and I have not had a problem yet. You don't have to replace that entire PCV hose that goes back behind the intake and over to the driver side valve cover.
I went to the dealer trying to get that same piece. They said that you have to buy the hose/PCV assembly. Mine had tore apart like yours. I'm pretty sure it was around 80 dollars. I ended up making my own out of stuff from Autozone.
dude same thing happend to mine they called it and engine breather... went to dealer and bought the $80 hose assembly but found out that I only need the little rubber hose tip that had the hole in it... so took the little part with the hole to autozone and they gave me a good replica of the little part that had a hole......So pull out that little rubber hose its only like 2"inches or less and take it to autozone and you will get a good replacement... FYI I took that $80 part back and got my money
Thanks for the link, I am buying the catch can. But looking at those threads I notice they all have the LS6 intakes and none with Ls1 intakes. idk
Are you saying you have no crankcase ventilation at all? That's not good. You should at least have a breather on there.
