Muffler shop guy just told me the factory cats are better than aftermarket hi-flows.
I told him I have a couple of hi-flows (3" Magnaflows) I need put on, and he told me now days the factory cats are better and that Magnaflow and whoever else is full of ****. lol. Is he right? It's actually a reputable shop, too.
My car also has 128K miles on it. I was thinking maybe it's time to replace them anyway.
I doubt the stock ones are better for performance but we had to take a set of new Magnaflows off of a car about a month ago. The cats took to long to heat up and start working. That would cause a catalyst inefficency code to be set.
LS1Tech Administrator
Received 1,466 Likes
"Better" is a realitive term. When it comes to longevity and filtering, that guy is absolutely correct; in that respect the stock cats are superior to anything the aftermarket puts out. Now, that's not to say that stock cats flow better (they don't) or are better for performance (they aren't). But when it comes to life span, and actually doing their job (filtering exhaust), a modern factory cat is better than the aftermarket stuff.
Throwing in an aftermarket cat won't give you much more than 5 HP if you're lucky. The factory ones are made much better now than what they were in the 70's, 80's and early 90's. Like RPM WS6 said, the factory ones filter way better, but the aftermarket ones have superior flow.
Well, I'd like a little horsepower increase. But if they're going to go out in a not-so-very-long time, then I would think twice about putting them on. My front oxygen sensors are going out, too, so the consensus was in another thread. How long would the aftermarkets last?
If your engine is stock, and running well, I'm sure they'll last for some time. But don't expect anywhere near as long as your 100k+ mile stockers have already gone.
Other thing to consider is price. I think you said that you've already got the Magnaflows? If so, you'd probably lose some money selling them, then pay a WHOLE lot more to get stock cats from GM.
Moral of the story: The GM cats will last much longer, but cost a great deal more. So if you keep the car long enough, the cost will probably equal out. As for power, if you're sticking with stock manifolds and a stock Y-pipe, then you'll probably not see any significant or noticeable power gain with the aftermarket cats.
What I would do: Assuming your current cats are still fine, I'd just replace the O2 sensors and be done with it. No need to replace factory cats for a stock manifold car unless they're bad.
I wouldn't necessarily say that they'll definitely fail in a short time, but it's possibile. I've seen a lot people here have Magnaflows go out in short order, but those are usually cammed cars that dump way more fuel into the exhaust which tends to burn up any cat quicker.
Just a couple months ago I diagnosed an SUV that had bad cats. The owner declined the 1500$ estimate for replacement factory cats. About a month later he was back with the check engine light on again with the same problem. The new Magnaflow cats he had were not doing a good enough job filtering the exhaust at idle and it was causing the catalyst inefficency codes to be set. The cats would work after they got hot but if the rear o2 sensors are still switching like the front after set amount of time it well set the code. That was the case with this vehicle and the man ended up having the Magnaflows replaced with factory cats like I suggested the first time. It is likely the muffler shop is trying to avoid this same situation.
While I agree that you shouldn't take just anything you hear from a muffler shop as gold, in this case I agree completely with the muffler guy.
I read an article years ago, and they had flow results from many different cats. The stock f-body cats outflowed all stock cats they tested by far. They flowed equally as well as the aftermarket ones they tested. I cant remember which ones they tested or any of the specifics, but i remember them saying the stock f-body cats were the best out there.
man, this info is new to me^ never thought the stock were better.
On the other hand, I can tell the OP, that my SLP dual dual are in since 3 years(+all years of the before owners) and no problem so far even if I'm H/C/I and has been running pig rich before my tune(2months ago).
I'd keep them, and when you get longtubes/y pipe have them put on. I wouldn't replace stock right now but might as well start fresh when you do more mods. Then, sell your stock cats and get $140 for them.
