New Orleans Put the greasy talk here...PiMp
shreveport/bossier hang out!
Old 10-20-2010, 06:14 PM
  #8341
SIC LSX's Avatar
Anyone have one stock rear sway bar end link? I need one.
Old 10-20-2010, 06:41 PM
  #8342
Goat's ss's Avatar
well Im putting my carbed 350 together went and cleaned a guy out earlier for a 350 and two turbo 350s one built a little bit and the other stock. Tunnel ram intake with 650s, edlebrock toker and performer intake.
The cam I got also is a 510/533 lift cam also roller rockers and some other various motor stuff that never been opened and installed.
Old 10-20-2010, 08:37 PM
  #8343
00silver6's Avatar
Sic I have some poly mounts you can have I gotta find them in the shed so don't hold me to it yet I'll look in the morning and let ya know.
Old 10-20-2010, 09:28 PM
  #8344
dfolse62's Avatar
Default 400 sb
Goat, I do have a fresh 400 small block that I am pulling tomorrow. If interested, call me at 422-2742. Darrel
Old 10-20-2010, 10:26 PM
  #8345
SIC LSX's Avatar
sweet thanks.
Old 10-21-2010, 10:40 AM
  #8346
02blackbeauty19's Avatar
Originally Posted by nitrobusa
I have had 2 different cars tuned by LG and a few mods performed by them also. They are great people and do good work, however their tuning was not the best in the world. Seemed to me that since I was not spending $10K plus they didnt spend quality time getting my car to my specs. I also had a car tuned by Jeff Creech at Thunder Racing and it was shitty.... plain Shitty! LMR (Houston) tuned my 08 Vette and did a great job but its a 10 hour trip and I'm not sure they do any better job than Greg Mcbride does. Just my 2c.......
I agree, they have done great work as far as mechanics of the car, however, the time Sean spent tuning my H/C/N2O car was just unacceptable, IMO. This lack of time showed as soon as I got home, used the nitrous on a slow interstate pull, MAJOR detonation.
Louis actually does great tuning from what I have seen, and has recently split from LG (his dads company) and partnered to open a new shop in Dallas.
I switched to Dallas Performance a couple years back and have been nothing but pleased. Taylor's attention to detail and knowledge is second to none, and I truly wouldn't take my Twin Turbo car anywhere else as long as he is conveniently and easily accessible.
Old 10-21-2010, 12:35 PM
  #8347
caddobass's Avatar
Just get in touch with Greg on here he is MCBR1228 for a good tune. I think there are several from here in the area that can tell you he does a great job.
Old 10-21-2010, 12:49 PM
  #8348
BadAssBowties's Avatar
Ive been searching and cant come up with a solid answer. I have a 2000 lq4 6.0 and wanting to put a th350 behind it. I want to say it will bolt right up but im not 100% sure. Can anyone here give me a for sure yes or no? Thanks
Old 10-21-2010, 02:22 PM
  #8349
blue98Z's Avatar
Shane I don't see why it wouldn't. There's several guys on tech that are running that combo. Besides that if the T56 will bolt up then the TH350 should since they do those conversions quite often. What happened to the 4L80?
Old 10-21-2010, 02:54 PM
  #8350
Nothing is wrong with the 80. Im going with the gmpp intake and msd setup so i cant use the 80. I know the th350 and 400s will bolt up and work but theres a big deal with the early lq4 having a longer crank or a spacer under the flywheel. My old lq had the spacer that could be removed. It was a 02 so idk if this has the spacer or the longer crank and if it even matters. BTW, im trading the 04 for a 77 firebird and going to put it on a strict diet with a little nitrous, gear, and a big stall. May even mini tub it for a set of 315s.
Old 10-21-2010, 03:19 PM
  #8351
Cold06's Avatar
No member with that name
Old 10-21-2010, 03:22 PM
  #8352
SIC LSX's Avatar
only thing left on the car is put oil in rear end and install sway bar
Old 10-21-2010, 03:36 PM
  #8353
SIC LSX's Avatar
OMG!!!!!!! LMAO
Old 10-21-2010, 03:52 PM
  #8354
MCBRIZ28's Avatar
I am also looking for a good tuner new motor should be in this week will need tune looked at. Last time it was in a f-body it only went 6.80's at 102mph in the 1/8 at 3650lb race weight all motor. The truck it was in made a little less than 500hp to rear wheels and 730hp on a 150 shot. The little motor has been setting a good while hopefully it will still perform.
Old 10-21-2010, 05:28 PM
  #8355
01ssreda4's Avatar
Didn't know you ditched the old LS1. What happened to it?
Old 10-21-2010, 05:41 PM
  #8356
Cold06's Avatar
I'll be cruising around Shreveport tonight if anyone wants to play just pm me and ill get it through my phone! But i got to stop in Minden and a TBSS first lol after i fix my tune
Old 10-21-2010, 06:16 PM
  #8357
Damn, I am always up for some runs but I started to change my valvesprings today....
Old 10-21-2010, 06:29 PM
  #8358
Goat's ss's Avatar
Damn, I got to find another sbc thats decently priced and a trans.
Old 10-21-2010, 06:37 PM
  #8359
MCBRIZ28's Avatar
finally took the plunge got the motor off Broz Powell he is going with a big block in the 02 drag car. Old ls1 was running fine won the street radial class at Prescott's last efi class had a 145,000 miles on it that night. The new one should be a little faster than old cam only 346 on a 170 shot just on motor. Haven't decided what to do with the 346 might just hang on to it wll be complete less intake
Old 10-21-2010, 07:50 PM
  #8360
SIC LSX's Avatar
Anyone have a on adjustable panhard bar??? I need one ASAP!!!
Quick Reply: shreveport/bossier hang out!
