New Products Showcase Come inside to see the newest hardware!
Tick Performance Remote Clutch SPEEDbleeder Line - Now Available for 2010+ V8 Camaro!
Old 07-20-2011, 05:00 PM
LS1TECH Sponsor
Joey@Tick's Avatar
Thumbs up Tick Performance Remote Clutch SPEEDbleeder Line - Now Available for 2010+ V8 Camaro!
Now Available: http://www.tickperformance.com/tick-...010-v8-camaro/
Bleeding the late model GM hydraulic system in it's stock form is a bear. You've got to have someone pump the pedal while you're under the car cracking the bleeder and hoping everybody's timing is right - not to mention keeping the reservoir full! It's easy to see how something so simple can quickly turn into a huge ordeal.
With our "One Man Job" Remote Clutch SPEEDbleeder Line, Tick Performance is taking great strides in making things much easier on you. At 4'+ in length, you're able to route the line to nearly anywhere on the car you want. Another huge improvement is our SPEEDbleeder end - allowing you to simply crack it open one time and close it once the air is out of the system, instead of having to open and close the bleeder with every pump of the pedal.
Why hassle with your hydraulic system every time you want to bleed it? Rely on Tick Performance to make the job much easier for you with our "One Man Job" Remote Clutch SPEEDbleeder Line. A must-install next time you've got the transmission out of your 2010+ V8 Camaro!
