Lingenfelter dual valve spring kit
Lingenfelter now offers this premium dual valve spring kit for use with camshafts under .675 lift. These dual valve springs kits include 16 lightweight titanium spring retainers, 32 7 degree bead lock valve locks, 16 spring seat cups, & premium OE style valve seals.
Technical Specs: Installed height: 1.800 Pressure: 160 lbs
Open height: 1.125 Pressure: 424 lbs
Coil bind at 1.085
Max lift at 1.800 .675
Spring Rate 392
http://www.lingenfelter.com/mm5/merc...w=&range_high=
Coil bind at 1.085
Spring Rate 392
