07-13 Silverado / Sierra 1500 Bolt-on Single Turbo Kit Available For Preorder Introducing our Strictly Performance Truck Turbo Kit for the 2007-2013 GM Trucks! Purpose built with the LS-enthusiast in mind, this turbo setup offers an effective solution for today's popular forced induction setups on the GM LS Truck platform. This kit is handbuilt here in the USA, not overseas and then brought over here to be re-labeled. You'll be hardpressed to find a higher quality kit available on the market for these trucks. This bolt-on kit is engineered to give you outstanding performance while maintaining your vehicle's factory-like fitment and reliability. We utilize all name brand components, no cheap knockoff products. There is no cutting or drilling your truck to install this kit. It is 100% reversible. This kit is designed to keep A/C and has heat shielding included ensuring proper function of the A/C system. This kit is ideal for street trucks as well as off-road applications as the intercooler sits up behind the grille instead of below the bumper. This Turbo kit is capable of producing over 800WHP. Our test truck gained 180whp at just 6 PSI producing 400whp with just this turbo kit, 65lb injectors, and an in-tank Walbro pump. That was on a completely stock engine, with the factory DOD camshaft and a stock 4L60 transmission! This kit utilizes the LS-Series Precision 7675 Turbocharger Rated to support 1,150HP. Featuring a 76mm cast compressor wheel and a 75mm turbine wheel, this turbocharger is an excellent match for the widely-popular LS family of engines. PLEASE READ: Your truck will need to be upgraded to support this turbo kit and horsepower. The stock fuel injectors and fuel pump are not going to support the fuel needed to turbocharge your truck. Most trucks with stock engines will be making around 400rwhp at 6psi of boost. The LS engine platforms are strong and we have seen customers make over 600hp on a stock motor. However, by installing this product onto your vehicle, you assume all risk and liability associated with its use. If you would like to purchase a motor capable of supporting 600hp+ checkout our Boost Prep 5.3 LS-Series Long Blocks or our custom build forged internal engines. Contact us if you would like to be put on our waitlist. Shipping date is expected to be in January. Link to the kit on our website (269)350-9055 Sales@StrictlyPerformance.Parts www.strictlyperformance.parts Precision Turbo LS-Series PT 7675 Turbocharger (HP Rating: 1150) Strictly Performance Stainless Steel Tubular Exhaust Manifolds, Crossover pipe, and 4'' Downpipe Precision 46mm V-band wastegate Tial 50mm Blow off valve Treadstone TR1245 4.5" Intercooler (Rated at 1000hp) Strictly Performance Aluminum Intake and Intercooler piping with MAF provision Vibrant Performance couplers and t-bolt clamps (black) Custom laser cut and formed intercooler brackets and hardware Complete Custom AN oil feed/drain kit Billet LS Oil feed adapter LS Timing Cover Oil return LS3/LS7 MAF Cartridge Style GM 2 BAR MAP Sensor Battery relocation kit Coolant expansion tank delete kit Retains Factory A/C Instructions for easy installation Note that the pictures below are of a prototype, and slight differences may exist on the production kits. (Intake/Filter is not shown in pictures, but is included in the kit.) https://cimg5.ibsrv.net/gimg/ls1tech...91848e6250.jpg https://cimg3.ibsrv.net/gimg/ls1tech...bc8c75b421.jpg https://cimg6.ibsrv.net/gimg/ls1tech...4c5572b394.jpg https://cimg7.ibsrv.net/gimg/ls1tech...c2c9aac396.jpg https://cimg4.ibsrv.net/gimg/ls1tech...dedc0364fc.jpg https://cimg2.ibsrv.net/gimg/ls1tech...d84e24e7e8.jpg https://cimg3.ibsrv.net/gimg/ls1tech...e31b20d082.jpg https://cimg4.ibsrv.net/gimg/ls1tech...df379cf0a1.jpg https://cimg2.ibsrv.net/gimg/ls1tech...3282173241.jpg https://cimg5.ibsrv.net/gimg/ls1tech...6d3b37bbfc.jpg |
© 2024 MH Sub I, LLC dba Internet Brands
