Notices
New Products Showcase Come inside to see the newest hardware!
FREE INSTALLATION Turbo/Supercharger kits
Old 02-22-2019, 11:07 AM
LS1Tech Sponsor
Strictly Performance's Avatar
Default FREE INSTALLATION Turbo/Supercharger kits
Purchase either our 07-13 GM Truck Turbo Kit, or our intercooled 07-13 GM Truck Torqstorm Superchargers Kit and we will install it for free for a limited time!
Link to the turbo kit
Link to the supercharger kit
Here's some info about the Turbo kit:
This kit is handbuilt here in the USA, not overseas and then brought over here to be re-labeled. You'll be hardpressed to find a higher quality kit available on the market for these trucks. This bolt-on kit is engineered to give you outstanding performance while maintaining your vehicle's factory-like fitment and reliability. We utilize all name brand components, no cheap knockoff products.
There is no cutting or drilling your truck to install this kit. It is 100% reversible. This kit is designed to keep A/C and has heat shielding included ensuring proper function of the A/C system.
This kit is ideal for street trucks as well as off-road applications as the intercooler sits up behind the grille instead of below the bumper.
This Turbo kit is capable of producing over 800WHP. Our test truck gained 180whp at just 6 PSI producing 400whp with just this turbo kit, 65lb injectors, and an in-tank Walbro pump. That was on a completely stock engine, with the factory DOD camshaft and a stock 4L60 transmission! This kit utilizes the LS-Series Precision 7675 Turbocharger Rated to support 1,150HP. Featuring a 76mm cast compressor wheel and a 75mm turbine wheel, this turbocharger is an excellent match for the widely-popular LS family of engines.
Turbo parts list:
Precision Turbo LS-Series PT 7675 Turbocharger (HP Rating: 1150)
Strictly Performance Stainless Steel Tubular Exhaust Manifolds, Crossover pipe, and 4'' Downpipe
Precision 46mm V-band wastegate
Tial 50mm Blow off valve
Treadstone TR1245 4.5" Intercooler (Rated at 1000hp)
Strictly Performance Aluminum Intake and Intercooler piping with MAF provision
Vibrant Performance couplers and t-bolt clamps (black)
Custom laser cut and formed intercooler brackets and hardware
Complete Custom AN oil feed/drain kit
Billet LS Oil feed adapter
LS Timing Cover Oil return
LS3/LS7 MAF Cartridge Style
GM 2 BAR MAP Sensor
Battery relocation kit
Coolant expansion tank delete kit
Retains Factory A/C
Instructions for easy installation
Some more info on our Torqstorm supercharger Kits:
This kit is perfect for the 07-13 Sierra / Silverado owner that is looking for much more reliable power at a more affordable price point. This Kit features our intercooler system that is designed and hand built here in the USA, for a perfect fit, excellent performance, and good looks. This bolt-on kit is engineered to give you outstanding performance while maintaining your vehicle's factory-like fitment and reliability. We utilize all premium, name brand components, no cheap knockoff products. There is no cutting or drilling your truck to install this kit. It is 100% reversible. This kit is designed to keep A/C as well. This kit is ideal for street trucks as well as off-road applications as the intercooler sits up behind the grille instead of below the bumper.
Our test truck made 455 hp 503
tq. (523 dynojet) 175 hp gain at 9.6 lbs. of boost. Pump gas, low timing. Only revving to 5500 rpm. Modifications to our test truck include BTR Stage 2 Turbo cam kit, Texas speed long tube headers (stock muffler), Walbro 525 LPH fuel pump, ID 1050x injectors
This billet supercharger is self-contained, 8 rib standard, v-band rotational compressor housing, stainless hardware, billet 7 blade turbo style impeller. Both the supercharger's housing and cover are precision-machined from billet 6061 aluminum. Depending on the application boost may range from 6-10 psi, a Limited lifetime warranty, Most importantly Made in
USA
Parts list for the Supercharger kit:
  • Torqstorm supercharger kit
  • Torqstorm bypass valve
  • ATI Fluid damper
  • Strictly Performance (SP) intercooler kit
  • Custom laser cut and formed intercooler brackets and hardware
  • Treadstone TR1245 4.5" Intercooler (Rated at 1000hp)
  • Vibrant Performance couplers and t-bolt clamps (black)
  • SP Intake for Torquestorm with K&N filter
  • SP Battery relocation kit with wiring
  • SP Coolant filler neck
  • Coolant expansion tank delete kit
  • LS7 / LS3 Cartridge style MAF
  • GM 2 Bar Map sensor
  • SP coolant overflow reservoir
  • Retains Factory A/C
  • Instructions for easy installation
Strictly Performance is online now
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
