200 N.O. Wet Plate what plugs?
Old 12-11-2008, 10:19 PM
STANG KILLA SS 2's Avatar
Default 200 N.O. Wet Plate what plugs?
jumping from a 5177 100 dry to a nitrous outlet 200 wet plate. currently running TR6 with whatever gap they have in the box
what plugs should i run with the new setup, and should i run a different (step colder) plug in #7?
what gap?
Old 12-11-2008, 11:33 PM
nahasapeemapetalon's Avatar
I cant find the part number but i would highly recommend calling ngk tech line and ask the part number for your application...get non projected tips, either 7 or 8 for plug temp.
I have had great luck with them.
"tr7" and "tr8" are projected tips, not recommended for larger shots 200+.
Get tapered threads.
NGK will give you number to order from local shop.
Old 12-11-2008, 11:34 PM
far as gap i run .030-.032
I also sanded the corners and edges to eliminate hot spots.
Old 12-12-2008, 06:12 AM
02SS:ZEUS's Avatar
I went from a 150 shot and TR6's to a 200 shot and Autolite's version of the TR8...which is actually half a step colder than the TR8. Mine are gapped to .032.
Old 12-12-2008, 07:40 AM
thanks guys. keep the suggestions coming, exact part #s would be great. (ie "here, by this you dummy" )
Old 12-12-2008, 07:56 AM
Randy WS6's Avatar
This should help
https://ls1tech.com/forums/nitrous-o...projected.html
Old 12-12-2008, 09:12 AM
great help. thanks
looks like BR7EF at around .031 is the final answer?
Old 12-12-2008, 10:15 AM
Nick@HSW's Avatar
Originally Posted by STANG KILLA SS 2
great help. thanks
I wouldn't say that. Just because something works for someone else, it does not guarantee it will work for you. I would rather see you start out with too cold of a plug than too hot. Let me know if you need a list of plugs. Thanks.
Nick
Old 12-12-2008, 02:07 PM
thanks nick your always helpful.
what info would i need to give you to help pick me a plug?
Old 12-12-2008, 03:31 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
we have the plugs you need in stock....you can get them when you pick up your kit
Old 12-13-2008, 12:02 AM
Id save time and call NGK. SOme of the numbers on that other post included a non tapered plug, i installed them and ran them..they work but were not tapered. As said above start colder, id recommend a non projected to be safe.
Old 12-13-2008, 11:08 AM
well spent about an hour talking plugs with ray last night. got me an edamacation
came home with a ton of info. pics and instructions of what to look for when reading/tuning plugs. and a full set of heat range 7 and 8 ngks.
turns out there is no easy way out. here buy these. lol gonna do it the right way and tune with plugs on the dyno.
Old 12-13-2008, 12:24 PM
Robert56's Avatar
Unless there are more than one style TR7, they are not extended tip plugs like the TR6. I run the 7 on my current 200 shot. But like Nick said better to start to cold than not cold enough as the final choice you have to consider what timing your running and what octane fuel you will be using and compression ratio, so one persons cure all may not work for the next person. My timing was 18° and something like 110 octane along with 11.25:1 comp, IIRC, i was running. worked for me and I won my dyno trophy with that tune. Here's a TR6 vs TR7 picture.
Robert
Old 05-10-2009, 01:41 AM
Braciole's Avatar
Thanks Robert!
Old 05-10-2009, 05:11 PM
CodeRed2000SS's Avatar
i run a autolite AR93 in my car on a 200 shot, but to each is own.
Old 05-12-2009, 05:08 PM
fastGBcamaro's Avatar
Do you guys running the non projected 7's and 8's have any driveability issues? I only ask because I still plan on driving my car on the street and to the track, and I would rather not have to change plugs when I get to the track because I plan on spraying a 200 shot. But if I have to I guess I will. Currently running tr6's in my 11:1 413cid LS2 on motor.
Old 05-14-2009, 07:24 AM
Nick@HSW's Avatar
Well honestly it is a colder plug. There will most certainly be driveability issues as well as fowling out at a quicker rate. Honestly if its not a daily driver, most guys can live with it.
Nick
Old 05-14-2009, 08:54 AM
ShiznityZ28's Avatar
I didn't read every post above did you post how much power it made on motor and or the 100 shot? the hp level will dictate the plug choice a bit but on a mild car an 8 should be the start on a 200 maybe a 9 if it made good hp on the motor. get the tune right then you cna see if it could use a warmer plug.
Old 05-14-2009, 01:31 PM
94 guy's Avatar
how do you determine the heat range based on hp?
Old 05-15-2009, 06:12 AM
Its not just hp but since we have built alot of ls combos if i knew what cam/heads he had and a rogh hp estimate i could figure out wht plug he needs on the motor. we have had cars use up to an 8 or 9 on the motor. the genaric "use a tr 6" is dangerous.
