Rear hump mounting
Yeah I hit the parkin brake mounting plate, had to grind part of the lip off to make it work. Also there was some wiring that I just barley missed. I think the wiring ran down the driver side of the hump. I lucked out and next time I will pull the carpet up enough to see whats under there.
Actually now that I think about it I hit the parkin brake mount when I drilled threw my driver side rear cup holder for my blow down tube. Had to grind the lip off with a die grinder and then weld a washer inplace to finish the blow down tube install.
Just drill in the rear holes first and then look under you should be alright. That's how I did it and there's nothin near there. You'll see it once you go under the car to put the washer and nut on the screw. I placed the mount as far back against the back seat without it actually touching it.
