What's causing this spark knock on the N20? http://i41.tinypic.com/nlvqc5.jpg As you can see on the 175 shot.. I have a HUGE gap of spark knock. The AFR was reasonable around this area..... It also did it on the 100 shot but at a higher RPM. The injectors are maxed out, and we upped the fuel jet to combat that and it still was running semi lean around the 4000-5000 RPM areas. We were only running 20 degrees of peak timing. Is it possible that it was sucking the rails dry? I have a walbro 255. It seems like if it was sucking them dry at 4500 rpm it would do the same thing.. even worse at 5500+ rpm. I did replace my fuel filter after the dyno, and a lot of black looking fuel and small chunks came out of the old one. Also, is it possible this is fake knock? Possibly caused by the open headers I was running or something else? It knocked even when we put max timing to 15 degrees. Thank you, Brandon |
Also, why in the hell does it stay so lean until the 3100 rpm mark or so?!?! |
We always tuned them off (knock sensors), they wont save the motor but they will slow it down. Lean til 3100 is in the tune.... the N20 doesnt hit until 38-3900. |
Originally Posted by ATVracr
(Post 11381320)
If you are going too lean pulling timing isn't going to fix you. Fuel upgrade? |
Originally Posted by goatboymatt
(Post 11382697)
it looks like to me that you are introducing too much fuel into the system and the injectors cant keep up... that is why you are still getting knock at 5100 because you have timing low to add fuel but it cant add that fuel because the injectors wont allow it.... my opinion ofcourse and could be entirley wrong. |
Originally Posted by camscam02
(Post 11388858)
(Post 11388858)
it looks like to me that you are introducing too much fuel into the system and the injectors cant keep up... that is why you are still getting knock at 5100 because you have timing low to add fuel but it cant add that fuel because the injectors wont allow it.... my opinion ofcourse and could be entirley wrong. I would start with a set of 42's. I am 417 NA and my duty cycle w/ 42s NA is about 65% without the spray. I have a Racetronics and then added a BAP. Was the Knock audible and did you capture KR in a EFI/HPT log? |
Originally Posted by Beer99C5
(Post 11389656)
I agree, I saw something similiar, on the dyno, the TQ/HP decreased when the Wet opened up and then the fuel pump recovered the HP/TQ picked back up. I would start with a set of 42's. I am 417 NA and my duty cycle w/ 42s NA is about 65% without the spray. I have a Racetronics and then added a BAP. Was the Knock audible and did you capture KR in a EFI/HPT log? Whats a good, cheap set of 42's for my car? |
| All times are GMT -5. The time now is 02:51 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
