Clearence Sale at Nitrous Outlet
Hey guys we are doing some reorganizing in the back of the shop. The items I will be listing we just want gone off the shelf. Take advantage of this and save. I will be adding to this post as we go. All Items are while stock last.
Please call the shop to purchase these items. They are first come basis. 254-848-4300 or 1-866-648-7637
1. NOS V-8 Universal Single Nozzle System. Part number 05131NOS Normal retail of 643.22-----COST 525.00
2. NOS 10&15lb Metal Bottle Brackets- Part number 14125NOS Normal retail of 48.71----COST 39.99
3. NOS 10&15lb Hinged Aluminum Bottle Brackets- Part number 14140NOS Normal retail of 135.84------Cost-110.00
4. NOS 10lb Bottle Blanket- Part number 14165NOS Normal Retail of 40.43----
Cost-35.00
5. NOS 15lb Bottle Blanket-Part number 14167NOS Normal Retail of 54.69-----Cost-45.00
6. NOS DRY Fan Nozzle- Part Number 13500NOS Normal Retail of 12.56----Cost-10.00
7. NOS Flare JET Y Fitting Red-Part Number-17256NOS Normal Retail of 18.47-----Cost-14.00
8. NOS Flare Jet Y Fitting Blue- Part Number 17255NOS Normal Retail of 18.47---Cost 14.00
9. NOS Liquid Filled Fuel pressure gauge and adapter- 0-120psi- Part number 15907NOS- Normal retail of 71.91-- Cost 55.00
10. NOS Alky/Nitrous Solenoid. Part number 16060NOS- Normal retail of 145.15---Cost-115.00
11. NOS 90 degree Blow down tube- Part number 16160NOS- Normal Retail of 25.47----Cost 20.00
12. Earles Polished -4 manifold fitting- Normal Retail 20.00----Cost 5.00 each.
13. Nitrous Express Red Rail Upgrade and Fittings- Already drilled and taped. Normal Retail of 324.89---Cost 230.00
14. Nitrous Express Purge Kit- Part Number-15601 Normal Retail of 125.99----Cost-99.00
15. Nitrous Express -6 filter- Part Number 15610 Normal Retail of 58.01---Cost 45.00
16. Brand X fuel Solenoid-30.00
17. 6 ft -4 hose with Black nuts- 10.00
18. Nitrous Express Twin Cylinder Motorcycle system with 2 1/2lb bottle- Normal Retail of 705.00----Cost 500.00
All Hoses below are 5.00 each..
3AN Hoses
2ft 3an Hose Blue ends
14in 3an Hose Blue ends
16in 3an Hose Blue ends
8 1/2in 3an Hose Blue ends
18in 3an Hose Black ends (2)
19 1/2 in 3an Hose Black ends
9in 3an Hose Black ends
7 1/4in 3an Hose Red Ends
7 3/4in 3an Hose Red Ends
4AN HOSES
18in 4an Hose Blue ends
12in 4an Hose Blue Ends
7in 4 An Hose Blue Ends
14in 4an Hose Black ends
6in 4an Hose Black ends
5in 4an Hose Black ends (2)
12in 4an Hose Black ends (3)
6AN HOSES
11in 6an Hoses Black ends (2)
7 1/2in 6an Hoses Black ends
5 3/4 6an Hoses Black Ends
4 3/4 6an Hoses Red ends
Cost-35.00
3AN Hoses
4AN HOSES
6AN HOSES
What email did you send it to? We had some serer issues that are now fixed. can you resend it to info@nitrodaves.com
Thanks
Dave
Thanks
Dave
PLEASE NOTE:
If you are ording a single item such as a low cost part shiping is going to cost more than the item. We have no controll over what UPS charges us for shiping. You may want to add some other items you need to make shiping worth your while. In most cases even with the shiping the order will end up being cheaper than if you were paying full price.
Thank you guys.
Thanks
Dave
Thank you guys.
Thanks
Dave
