What plugs and advice?
Injectors. I've got 42lb's in my 408.
At a minimum #7s but if you're at 500 rwhp now plus 125 shot (i assume to the tire) you're in the 625ish range. I will be going to #8s at the 600 mark.
I would run an 8# heat range plug.
Ask who ever tuned the car with the 36s in it when you got your hp numbers to look back at your tune and see where the duty cycle was on the tune. 36s should be fine for the motor but they will mopre than likely not be enough if you are using a dry set up.
Dave
