LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Nitrous Oxide (https://ls1tech.com/forums/nitrous-oxide-10/)
-   -   Mallory 685 doesn't work with LT1 pcm (https://ls1tech.com/forums/nitrous-oxide/1453858-mallory-685-doesnt-work-lt1-pcm.html)
lncboytre_d Aug 9, 2011 10:38 AM
I have been having trouble getting my car to fire up while the mallory 685 box is connected. If I use the by-pass it fires right up. This is the second box in two weeks, and I have went over the wiring several times. I called Mallory and the tech line rep told me that the mallory box was not compatible with the LT1 pcm. WTF!!!!! Someone please help. I know there are guys using the box. Why won't mine start?:bang:
Graham@NitrousOutlet Aug 9, 2011 10:39 AM
Let me get with some of my lt1 guys. See if I can get them to chime in.
neat Aug 9, 2011 07:23 PM
What year is your car?
You might call Century Performance. That's who I got my MAL685 from and their phone tech support is great. www.centuryperformance.com
A great resource for OBD1 guys is Jim's Performance in MD. Jim helped me over the phone through the MAL685 and a retro fit from HEI to small cap and LT1 style coil, so he's pretty up on his wiring with that box. http://www.jimsperformance.com/
You might try grounding the case of the box. That helped with longevity in my car.
I went through several boxes when I had the MAL685 under the hood. For me, they were super sensitive to water. I moved the box to inside the car and haven't had a problem in years.
It sounds like you are having luck making the box work at first, and then it dies over time. I have seen some of them that randomly adjust the start retard as the box cycles. You might want to check that if I am interpreting what you are saying correctly.
lncboytre_d Aug 9, 2011 09:28 PM
The car is a 97, OBDII, the box comes on, the start retard is set at .01, I will check out the guys over at Century Performance and see if they can help. Thanks for the input
96TransAmboosted Aug 10, 2011 10:30 AM
Are you not using the plug and play harness? This will eliminate most issues. Ill snap a pic when I get home. But if I were you I would switch to a digital 6 msd
gregrob Aug 10, 2011 01:45 PM
Are you using the MSD harness? If so what part number?
Tell me exactly how you have it wired up, wire colors and all.
lncboytre_d Aug 10, 2011 02:55 PM
Yeah, I used the msd harness part number 8877. I wired it black to black, green to white, red to red, and yellow to orange. I am really close to sending this box back for an msd 6. I am going to keep working with this one for at least the remainder of the week. What part number is the msd 6? Does it have a window switch and high speed timing retard?
lncboytre_d Aug 14, 2011 12:40 PM
Well, I took a test light and checked each wire coming from the box to the wiring harness, each wire is hooked up correctly. Again, I connected the by pass harness and the car fired right up. WTF!!!. I just got off the phone with summit and they are going to send out box #3. The sales rep apologized and stated "we'll get it right this time". I surely hope so.
On another note, I took the car out and sprayed 50 down the tube....for those who say you can't feel or tell the difference with such a small shot is full of $h!t. It was by no means a rocket car, but it definately added a power you can feel. I sprayed from 65 to 120 and then from a dead stop. I can't wait to get that 150 shot going.
Graham@NitrousOutlet Aug 15, 2011 08:41 AM
Crazy...
I hope we get this all taken care off soon.
© 2026 MH Sub I, LLC dba Internet Brands
