LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Nitrous Oxide (https://ls1tech.com/forums/nitrous-oxide-10/)
-   -   Nitrous isn't activating... (https://ls1tech.com/forums/nitrous-oxide/1454706-nitrous-isnt-activating.html)
01SOMZ28 Aug 11, 2011 03:02 PM
1 Attachment(s)
A few months ago i replaced all my old nitrous components with new Nitrous Outlet parts. I hate wiring and i'm not good at it, so when i unhooked everything i labeled each wire so i could just match them back up. When i was finished, i went out to test it....and got nothing. A couple months have passed and i went out and re-wired the entire thing fallowing a basic diagram, i also hooked my purge back up. Well, i went out to test it again and i still got nothing! The purge works but the noids are not activating. The purge is hooked up to it's own power supply but the ground is tied into the noids and relay grounds ... :confused:
Attached is the diagram i fallowed, minus the FPSS. One thing i did do different, is i tied all the grounds together (relay ground & solenoid grounds) I'm 90% sure i did it right. I mean, it's so simple, how could it not be working? :bang:
Graham@NitrousOutlet Aug 11, 2011 03:20 PM
I blame the Diagram! (Kidding)
Have you set the FPSS?
01SOMZ28 Aug 11, 2011 03:41 PM
I don't have a FPSS.
Graham@NitrousOutlet Aug 11, 2011 03:41 PM
Have you armed the system and tried clicking the WOT switch with the bottle off and the car off?
01SOMZ28 Aug 11, 2011 03:48 PM
Sure did and got nothing. My dumbass probably wired it wrong, somehow....yay. I can not stand wiring.
Graham@NitrousOutlet Aug 11, 2011 03:50 PM
I hear you.
Check the power and ground coming into the microswitch. See if it is the switch itself.
01SOMZ28 Aug 11, 2011 03:54 PM
The micro switch has been on the car for about 4 years. Is it a possibility that it took a shit? Does that happen very much? I guess i have never heard much about a micro switch going bad.
Graham@NitrousOutlet Aug 11, 2011 03:55 PM
Not very often. But its pretty much that or the relay unless you did something "Challenged".
01SOMZ28 Aug 11, 2011 05:48 PM
Micro switch is good. Still can't figure it out. When i look at it, everything looks good to me. I'm confused.
wfritts911 Aug 11, 2011 05:50 PM
Maybe the relay gave out? Or maybe you switched a couple of connectors on the relay? Try putting a direct pos/neg to the terminals to see if it clicks. Then test to see if the microswitch is passing current.
-Will
TA1364 Aug 11, 2011 10:12 PM
What window switch do you have? Hit each selonoids with 12volts(I think) and that will rule out any grounds.
minytrker Aug 11, 2011 11:02 PM
I would check and make sure you wired relay correctly. Use a jumper wire and hook 12v straight to the nitrous solenoid with the bottle off and see if it clicks.
Canbarelygo Aug 12, 2011 01:23 AM
maybe the arming switch itself blew up due to the badassery of the solenoids. i had an arming switch blow up on me once
01SOMZ28 Aug 24, 2011 02:20 PM
Figured it out, bad relay. It works....now i just need to go spray it since it has been far to long! (Oct. 2010)
transamws600 Aug 27, 2011 08:36 PM
aannnddd?
© 2026 MH Sub I, LLC dba Internet Brands
