Timing tuner?
Old Mar 10, 2004 | 12:29 PM
Roadrunner 45's Avatar
Default Timing tuner?
Was about to buy a MSD window switch when I saw that the timing tuner also advertises control of some nitrous parameters. can anyone answer these questions:
1. Will the timing tuner function as a window switch, or only activate the nitrous circuit?
2. Can I use this to retard timing while on the spray without screwing up my dyno-tuned program that is used for n/a driving?
Old Mar 10, 2004 | 03:31 PM
houseofboost's Avatar
Good question. Hopefully someone will answer you...for both our sakes.
Old Mar 10, 2004 | 03:40 PM
LS1 Power Plant's Avatar
I'll try.
Both.... It will activate the nitrous working as a window switch. You set when it comes on and when it turns off (the Timing Tuner with the old firmware will only let you pick from 2 RPM values to turn off, the new firmware lets you pick any value).
Yes.
Old Mar 10, 2004 | 09:19 PM
Great! So one more question- is there any reason I'd be better off going with the MSD switch?
Old Mar 10, 2004 | 09:40 PM
Not that I can see.I love my TT, but one thing. You might have to re-wire your system to get the TT to work, depending on what N2O kit you have. Not that big of a deal, but still....
Old Mar 11, 2004 | 07:33 AM
should be OK as I have a brand new NX kit- not installed yet.
Old Mar 11, 2004 | 09:20 AM
Chris99WS6PWTMET's Avatar
Ramcharger's Timing Tuner works excellent in a nitrous application. It was well worth the $280.
Old Mar 11, 2004 | 01:31 PM
Dave@Ramchargers's Avatar
We have them in stock $259.99 plus handling
Let us know if you need one
Old Mar 11, 2004 | 03:07 PM
BLUEBYU's Avatar
Ok, I have posted this before......so here goes again. If you have access to LS1 Edit, you can adjust the PE vs. RPM table at high load to lower the timing. Typically somewhere around 0.800 load value and above, for nitrous simply lower the timing from where your MSD turns on and off (typically 3000 - 6400 rpm). It is pretty cool to see how it works on the tap files.
