What fuel setup for 2 stages
Old 03-14-2012, 12:40 PM
98LS1driver's Avatar
Default What fuel setup for 2 stages
PlannIng on running a dual plate setup with 100 on each system looking to see what pump and rails and such would I need to get in order to support the system? Car Is ls1 basic bolt ons thanks for the help
Old 03-14-2012, 01:20 PM
Nitro Dave's Nitrous Outlet's Avatar
If the engine is stock you would be fine with a racetronix system.
Dave
Old 03-14-2012, 02:05 PM
It is stock and where can I get more info on this system and what timing would be safe to start at and with what tuner
Old 03-15-2012, 01:30 PM
Dave
ordering the pump with the wire kit and all the goodies anything else? What would be the best way to tune it too which software? and a decent timing curve to start at because i will be doing 100 out the gate and 100 on second stage just in case . Its pretty much a grudge sleeper car on radials
Was thinking of doing a single plate with 150
Old 03-16-2012, 05:58 AM
bttlfed's Avatar
Get a progressive controller, don't waste ur money on two stages. Especially on a 200 shot.
Old 03-16-2012, 08:57 AM
Fbodyjunkie06's Avatar
Well if he has a dual stage plate already he may as well use it.
Get a dual stage window switch that has a gear lock out and delay feature. That way you can come out the hole on one stage and delay the other for however long you need it.
2* timing per 50hp of nitrous is a rule of thumb. Most pull an extra degree or two on top of that to start with, almost 9/10 though the initial jetting will be rich and a bigger nitrous pill or smaller fuel jet is needed to bring the afr in line with what the plugs are telling you.
Old 03-16-2012, 10:43 AM
What plugs are good to go with?
Old 03-17-2012, 09:24 PM
BR7EF's for 100-200 shot. Anything above that I'd think about going to a BR8EF
Old 03-18-2012, 10:22 AM
K thanks!
Old 03-18-2012, 10:26 AM
What gap?
Old 03-18-2012, 06:07 PM
Originally Posted by 98LS1driver
What gap?
Honestly I couldn't give you a good answer on that one.
I think they come out of the box @ .35.
On my boosted car I ran them out of the box.
Not the same set-up here though. Maybe camscam, atv or nitro dave can help you out or carter01 I'd bet camscam and carter run that BR8EF plug.
