What's needed to run nos wet kit? Ok, I have a heads/cam car putting out around 400 rwhp. What all would I need to run around 100-150 wet shot? I know I need to upgrade fuel pump, injectors. Do I need to do anything else to the engine or should it hold that fine? Probably won't spray a lot, only when I need it. |
Re: What's needed to run nos wet kit? Clutch(if standard),rearend,Fuel pump,Sticky tires(DR's) Engine should hold 100shot if tuned properly.150 might be pushing it on pump gas. |
| All times are GMT -5. The time now is 04:04 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
