arp's needed to spray? is it a must have item to spray a stock motor with a 125 shot? would arp head bolts be ok or should i just get studs? |
Unless you have to take your heads off for other reasons then you should be ok with stock head bolts. If you are replacing lifters or heads etc, then you should add ARP bolts. Just a good upgrade for 100 bucks. You can add studs if you like but they aren't really needed at this stage and usually range around 240 bucks. ARP bolts will fasten and hold just fine. |
thanks for the quick answer |
No prob |
| All times are GMT -5. The time now is 11:08 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
