NX or TNT for 175 rwhp
i got the nx shark nozle spraying 150shot and people keep telling me that u don't wanna spray over a 150 with it.
do i need to upgrade for the TNT F1 wet kit or stay with the nx, to spary 175
I wouldn't spray anything bigger than a 150hp shot through a single nozzle. I don't believe the orfice is big enough to evenly atomize the nitrous/fuel mixture for shots bigger than 150.
If you've already got the NX wet kit, all you need are 2 T-Fittings, 2 more steel-braided lines, and another nozzle. You can set your NX kit up just like a TNT kit, but save some money.
Good luck.
Good luck.
Restricted User
I can say that it actually atomized any better, but used to spray the 175 NX a lot of bottle worth. Just use a mix of race gas, right spark plugs, reduce timing and have fun. I sprayed 200 a few times, and theres a guy from vegas side that nailed it, as well as 250 I think he shot 300 a few times. Basically on a stock bottom anything over 150 is rolling dice. Good luck.
