[First nitrous install] LS3 with NX 90mm plate system
Hey LS1tech,
My name is Justin and I have an LS3 cam-only vette that I race on the regular and I wanted to try my hand at adding nitrous to my car.
I went with the NX 90mm plate kit, purge, progressive controller, fpss,etc
Here are some pics from the install. The main nitrous feed line is way too long so I'll be cutting off the excess and adding the fitting so it isn't so messy.
Comments, critiques, and thoughts are welcome. Thanks!
All the goodies(almost)
Initial solenoid placement but it was way too busy. I ended up ordering custom lines to clean up the install and mount the noids together.
The fuel line is still 1" too long so I have another line on the way to clean up the lines running from the noids to the plate.
Fuel rail tap and FPSS
Bottle mounted to pressboard, sandwiched in between the insulation and rear carpet
Nitrous Outlet switch panel wiring
Tapped into the VSS, tach signal, and TPS wires at the ecu so I didn't have to run wires everywhere in the engine bay
Nitrous feed, battery positive(1 gauge), wideband, timing box, and all nitrous wiring go through these holes in the firewall.
There are essentially 2 tunes loaded in the car and they change at the flip of this switch, thanks to resistors used to set the ECT to exactly 237* which allows a whole new timing map to be written
I also relocated the battery to the rear hatch compartment in preparation for the standalone fuel cell to take its place up front
HP Tuners interface, NGK AFX wideband controller, and Maximizer 4 progressive controller all secured in the glove box.
I didn't want to have to fuss with filling the bottle so I bought a mama bottle for the garage
Lastly, I ordered a new custom plate
The end goal is a 9 sec slip which I think is doable with a 150 shot
Whose solenoid brackets did you use?
I have baby pills in it right now(75 shot) as I don't think my stock fuel pump will take much more. I could add a bigger fuel pump or twins in the tank or something, but it's such a chore to do that on the vettes that I'd rather just buy a standalone and put it in the battery tray. The solenoids are located nice and close so I won't need to run excess fuel lines all over the place. It'll still be nice and clean.
That's actually NX's solenoid bracket. I had some issues along the way with their packaging(they forgot to send the universal brackets) so they offered to ship me that bracket free of charge. It was designed to mount to the throttle body but with the purge, there's not enough room. You also have to relocate the power steering reservoir and I didn't want to do that. Ironically enough, that bracket fits PERFECTLY on top of the coil and is so snug, I didn't even have to bolt it down. I just ran a couple zip ties through the opposite side and it doesn't move.
I like to know more about the:
part??! any write up or info on 'how to' would be great.
Thanks
Thanks
Thanks
Thanks
Thanks Trey, give Abney the link as he wanted to see pictures of the install. I'm still not done with it, but it's pretty close.
The one thing I really like about NX kits is that they come with the -6 line and fittings already as part of the base package where as N2O outlet does not. I also really like their DF5 bottle valve it seems to really flow a lot more than others.
I am pretty sure with that maximizer 4 you can delay the nitrous .10-.15 to get rid of the lean spike.
Does it lose performance when the lean spike happens? Most of the time a lean spike is normal and it really won't hurt anything as long as the timing is pulled when it occurs.
With the max 4, I can ramp in the shot, but I don't see an option to separately control the nitrous solenoid. I haven't experimented with it yet so maybe putting a slight ramp in the curve on the hit will help. It's only for about .15 of a second and the timing is pulled so I think it will be ok. I might call NX today to see if I'm just missing something as far as using the software to delay the nitrous noid.
No performance is lost that I can tell. It's a very small shot as I'm taking baby steps to get used to everything.
