what to put on fittings so nitrous wont leak?
ok i know the AN fittings are goos, but what about the NPT? like the purge and gauge, i put liquid thread sealer but it seems like i have to tighten it so tight to get the hissing to go away. any tricks?
Old School Heavy
This is this is the one they say not to use:
Loctite® Threadlocker Red 271™ is designed for the permanent locking and sealing of threaded fasteners. The product cures when confined in the absence of air between close fitting metal surfaces. It protects threads from rust and corrosion and prevents loosening from shock and vibration. It is only removable once cured by heating up parts to 500°F (260°C).
Loctite® Threadlocker Blue 242® is designed for the locking and sealing of threaded fasteners which require normal disassembly with standard hand tools. The product cures when confined in the absence of air between close fitting metal surfaces. It protects threads from rust and corrosion and prevents loosening from shock and vibration. Loctite® Threadlocker Blue 242® is particularly suited for applications on less active substrates such as stainless steel and plated surfaces, where disassembly is required for servicing.
There was a product called Loctite Thread Sealer 545 that came in a red bottle, but I am not sure if they make it anymore. it is not listed on the Loctite website. This may be an ad for "new old stock": EDIT: I doubt this is a good choice though, the TDS sheet says this: This product is not recommended for use in pure oxygen
and/or oxygen rich systems and should not be selected as a sealant for chlorine or other strong oxidizing materials.
If somebody uses Loctite® Threadlocker Red 271™ they are likely going to be real unhappy when disassemble time comes.
