NEED HELP Purge won't seal...bad Nitrous leak..
I can't get it to seal around my purge.... it leaks bad were the 1/8" NPT goes into the purge solenoid and the 1/8" NPT that screws into the manifold on the nitrous line... I've tried Teflon Paste and it won't work it leaks bad any help or suggestions please this is really pissin me off thanks for the help
Make sure there is no thread dammage, then try teflon tape it may seal better.
Good luck. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Did you try letting the teflon paste sit overnight before checking again? Mine went ahead and sealed overnight after having a few problems with it.
no i didn't let it sit overnight I was told that it doesn't have to sit at all either it works or it doesn't ... will it work better after it sits??
