lq4 popping at 7k on nitrous but fine on motor
Ok so I have been spraying 175 through a direct port setup for a long time. I decided to up the jets to a 200 and there comes the problem. I hit the nitrous right off the t brake and it pulls hard until 7000 where it sputters like a rev limit. I made sure the msd 6010 rev limitissethigher. If i do a pull on motor i can go to 7500 no problem. Thisissue just started as i increased the jets. I have an aeromotive pump feeding the regulator set flowing at 5.5psi. I am lost....pleasehelp guys!! Ok so I have been spraying 175 through a direct port setup for a long time. I decided to up the jets to a 200 and there comes the problem. I hit the nitrous right off the t brake and it pulls hard until 7000 where it sputters like a rev limit. I made sure the msd 6010 rev limitissethigher. If i do a pull on motor i can go to 7500 no problem. Thisissue just started as i increased the jets. I have an aeromotive pump feeding the regulator set flowing at 5.5psi. I am lost....please help guys!!! The plugs are br7ef and replaced with .026 gap. Fuel pump flows 150gph. The carb is a pro systems unit.
