I can't believe it >>>>>>
Old Jun 6, 2002 | 03:26 AM
RGVelite's Avatar
Default I can't believe it >>>>>>
Well i was running 12.60 on motor. I went to MTI to get a B1 cam installed and custon tune. I told them to tune so it could run on NOS. I make a motor pass this friday and hit a lowsy 12.80 on motor. Then i hit first stage of the juice off the line which is 50 and get a 1.67 60 ft. An unbelievable 11.91 at 114 mph. Is this normal and with second stage 75 will i hit 10.90 or NAHHH.
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jun 10, 2002 | 04:17 AM
AlonzoVersion 1.0's Avatar
Default Re: I can't believe it >>>>>>
Your motor times will be slower now because they pull out timing for the juice and no I dont beleive you will hit 10.90s but I have been known to be wrong.
Old Jun 10, 2002 | 04:45 AM
If I were you I would have them put the timing back up to where it was andbump up the pills on both kits and run race gas only when you hit the bottle or bottles.
