Nitrous Backfire Hello there, I'm running a C5Z and I want to know if anyone of you guys had a backfire before .. cause I have an question if you had backfire did the wheel-steering locked ? so you can't move it at all? as same as the C6Z or it's not ... cause we have seen a lot of C6Z on fire and the reason is they can't turn off the car at highspeed, if it's locked in C5 how can I solve this problem? thanks. |
so no one have a backfire before on high speeds!! |
Originally Posted by ZeOhhSix
(Post 16789294)
Originally Posted by 03EBZ06
(Post 16790343)
uh, yes, but never seen the steering wheel lock. There is a sensor on the steering wheel for the c5z that detects turn position. I had to have mine replaced on my car. It locked, but not using nitrous. That should be unrelated unless of course a wire was burned or something odd. |
turn it off and back on quick... |
© 2024 MH Sub I, LLC dba Internet Brands
