How far do you roll out before you spray?
I hear ya on that, only problem is if you get that tank rolling and then try and spray it more chaos might ensue.. I know it's not always the easiest or cheapest, but I would get some axles and C-clip elims in there.. My preference is replacing the housing ends with a bolt in housing end and a bolt in axle..
I just did this for a customer with a 78 Camaro 3500#'s BBC on spray.. He was tired of killing C-Clip elim kits...
off the brake if u spin try at the tree if not u'll have to take it a lil after the tree but off the brake is the best for me. even tho i spin most of the time my best time was spaying at the tree 100 shot stock 10bolt....
launching
what kind of tires are you using ???? even with my drag radials im blowing my tires off ,im llaunching @3 my 150 come 0n @3000 rpms at wot, 17psi in tires 60ft are in the 2 ,ant ideas where i could help my 60 foot it , no stutter box
nox launch spin
sry i mean, i hold the car at 3000 rpm and lauch it out of the hole the m/t drag radials just spin, then i go wot and the nos hits and spins more just not getting a good bit , dont like having to pedal the gas would love to hook a least one good time , last time i got it to hook the track was real good ,i broke the out put shaft , up graded that have had no luck hooking since . removed front sway bar today and going to try that? I,m open to any suggestions
Adjustable shocks and proper rear end geometry.
I can get you set-up with front and rear QA1's for $1009.99. These are coil-overs with springs for that price.
Speedtigger- I would hit it right out of the hole. I think you will make more problems for yourself trying to hit it after the car is rolling. I think you will unsettle the suspension or end up with wheel hop.
Try to hit it out of the gate if you can at all possible.
