Is it 9's worthy? Nitrous setup So ive been messing with my project car for monthssss. Changed plans from turbo build, to cam only build, now I have finaly pulled tge trigger and not changing and doing a nitrous setup for now. Here is mysetup, let me know what u guys think of it, what I shoukd change and is 9's even realistic Specs: 2900lbs (rx7 *with me in it*) 10 gal fuel cell 044 pump Th400 rmv, trans brake etc. (rossler t2) 4000 rpm nitrous converter (dont have yet) Ford 8.8. 3:55 gears, 35 spline, spool, narrowed etc.. (tri 4 link) strang coilovers 110lb springs Lq4 shortblock stock arp rodbolts 317heads ported, dual springs 9.5-9.8 compression 1 3/4 long tubes hardened push rods trunion upgrade TSP ls6 ported blueprinted oil pump Cam (not sure yet still need to buy one) Holley hp efi computer 150 wet nozzle kit 275/60/15 tires m/t drag radials Hoping to be close to 400 n/a (380-390) and hit a touch over 500 on spray (510-15) |
Easy..... Just research and learn how to tune the nitrous and suspension. At 2700lbs you should go deep into the 9s. |
Thanks for the input, just read that article on GMH WOW, you car looks so sleeper. maybe ill switch over to a 78mm plate with 200shot if the nozzle doesnt work. Maybe a sponsor can "lend" a man a plate :hump: |
I wouldn't say it will be easy. It's possible but will definitely take some tuning. Your compression ratio is not doing you any favors on making power with spray. |
Ya thats the part iam nervous about. |
Originally Posted by Carter01
(Post 16849794)
Originally Posted by speedtigger
(Post 16853816)
If my recent experience is any evidence, I agree with Carter. I would like to see my car at 2700 lbs. |
what do you guys think of the 3:55 gear? |
That combo should go into the 9s with the 3.55 if everything works and you hook. They should work fine and help you hook up. |
You are leaving an easy 3-4mph on the table with that mild compression.... Miles better with 11.25:1 or more compression. When you spray spend the extra dough and run some 100+ octane fuel for safety barrier. Use this calculator to see if those gears are optimal. www.f-body.org/gears After paying a local tuner $600 to tune an n/a LS2/LS3 top end combo and him taking 1.75hrs total...... I bought a Holley HP EFI myself for my LS7 RX-7 to never be at the mercy of a tuner again. fawk that BS. |
your compression is fine... i was doing some reading and higher compression doesnt "use" as much of the nitrous as you shovel in. the lower compression will use more of it... but if in doubt.. put in bigger pills!! |
a nitrous motor still has to draw air in therefore yes he is leaving a lot left on the table with low compression, because we dont have air being forced in we need to move as much air in and out as possible therefore we nitrous guys need more compression, and there is more to it than just compression. |
Originally Posted by baycityrides
(Post 16879411)
your compression is fine... i was doing some reading and higher compression doesnt "use" as much of the nitrous as you shovel in. the lower compression will use more of it... but if in doubt.. put in bigger pills!! Get the compression up, nitrous just like anything else likes as much compression as you can give it without detonating. If you need a cam let me know I'll be glad to spec you out one. |
Over the years nitrous engines have gone up and down with compression. For awhile low was the big thing, then huge, now it's kinda leveled off.. If you have the right cam for your application you will go into the 9's fairly easily with competent tuning. Is the compression *optimum*, I would say no.. To go 9's at 2700lbs, I think it's more than adequate. I'd like to see what the motor I built for WhiteLTone would do at 2700lbs. |
| All times are GMT -5. The time now is 11:43 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
