NX Nitrous Kit install on 02 Camaro I have an 02 Camaro z/28 with an auto that iam going to be putting a NX wet kit on. I got the kit used and this is my first camaro and nitrous install. I was wondering the following questions: -should i upgrade the stock fuel pump *easiest way to get it out*? -do i need a tune? -what is a safe size of jet to use? -any other tips/tricks? This is a 02 75,000mile camaro with an auto. Im looking for a run reliable car. Its also going to get a yank ss3600 convertor and a set of 3.42 gears. |
I am new to it but I have some tips Yes, you need more fuel Yes, you need a WOT switch Yes, you need a tune to get the most out of it 150 shot is a good shot on stock stuff w/auto check your kit for sizes keep you bottle pressure up and use a heater instead of a torch. I love my new NX kit. My purge stuck due to some trash i picked up at the fill place, (new kit and bottle) but i had a BLAST with it. Last, auto helps keep the stock rear end from breaking but if you use sticky tires and go from a dead expect to tow it. Just some of my experiances. http://i116.photobucket.com/albums/o...BluezDFT11.jpg Pic of stuck purge, still ran 7.6x at 95 in the 1/8 on the stock pos rear with DR's |
Originally Posted by qcga
(Post 16917567)
I have an 02 Camaro z/28 with an auto that iam going to be putting a NX wet kit on. I got the kit used and this is my first camaro and nitrous install. I was wondering the following questions: -should i upgrade the stock fuel pump *easiest way to get it out*? -do i need a tune? -what is a safe size of jet to use? -any other tips/tricks? This is a 02 75,000mile camaro with an auto. Im looking for a run reliable car. Its also going to get a yank ss3600 convertor and a set of 3.42 gears. If your car is bone stock you might be able to get away with no tune as far as timing goes, up to a 100 shot in my book. Did it on 4 different bone stock cars so far and plugs looked fine after a night at the track. In your case for size of jetting, I would start small at a 75-100 shot. Everybody's jetting is different so I don't know the jet sizes for NX. When you put the stall and gears in, throw a set of longtubes on it and get a tune with all that on the car. After that, get a timing tuner (lingenfelter box) to pull more timing so you can spray more. Make sure you get a set of colder plugs too. The part # you will be looking for is br6ef (stock # 3177) it is 1 step colder and non-projected. That will be good for the 100 shot, when you go bigger, step up to br7ef (stock #3346) thats 2 steps colder. Be safe adn have fun!:drive: |
© 2024 MH Sub I, LLC dba Internet Brands
