How much extra timing to pull for every 10 degrees temperature increase
You might wanna do a compression or leakdown test in that cylinder.
Thanks for the feedback and you are right it did need more fuel. The interesting thing is when I ran my 92/92 FAST set-up I was jetting 78/42 running consistent 10.50s. When I swapped to the 102/102 set-up with 100mm Maf it only wanted a 36 fuel jet and ran the same times. Don't know why that would be - perhaps someone has some thoughts. In any case swapped to a 3.73 gear this year so I can run a 28 inch tire - picked up 4/10ths on the n/a pass! On the nitrous passes was twisting and forcing the rear passenger side fender skirt into the tire so could not get any passes before doing some more trimming and adjustments. Always lots to learn but looking forward to some good times this year! Thanks to everyone for the feedback!
