Plug vs Shot Guys what's the rule of thumb people are working on in relationship to how many steps colder you go on a plug vs shot size. |
One step colder per 75-100 hp seems to be the general average |
Originally Posted by HCI2000SS
(Post 17982542)
One step colder per 75-100 hp seems to be the general average -Garrett |
Thanks guys. I'll be running a 150shot. And stock for me is a BPR6. So I'll go a 7 and see how it goes as it's mostly a street car that won't get sprayed all that often. So ideally an 8. But not to keen on that for majority running just on motor. Are there tuning tweaks to reduce the need to go 2 steps colder. |
The BR7 will be perfect for your application. That's what i'm running on a HCI 6.0 with a 100 shot. With a good tune there will be no issues with this plug |
(Post 17983469)
Originally Posted by macca_779
(Post 17984786)
The plan is to go a 150shot though so going off the above advice going to an 8 would be preferred. I'd just like to know if there is a way to mitigate having to go to the 8. i.e. run it richer/leaner/less timing? |
(Post 17984786)
(Post 17988416)
The BR7 will be just fine with a 150 shot on your setup. Why exactly do you think you need an 8? |
(Post 17988901)
Just the rules I'm hearing are 1 step colder per 100shot. Can't do half sizes after all. But thanks I'll run with the 7. |
(Post 17989053)
Well the BR7 is 2 steps colder than stock, and it doesn't have a projected tip. It really is more than fine just so you know |
(Post 17989116)
Not here it isn't BPR6EFS-15 is standard for Aus LS1's |
Im running the br7 on a 125 shot. I might step up to a 150 myself. |
im running a 6 heat range plug, 200 shot on a 5.3. and my buddy has a 02 ws6 he has sprayed up to a 150 on tr6 plugs with timing adjusted accordingly.... i think youll be fine with the br7 on a 150. |
and im going br7 soon ill be upping the shot too. |
© 2024 MH Sub I, LLC dba Internet Brands
