Sprayin with a 4.56
so if 28" + 4.56 is not possible, but 4.10 and 26" et streets are ok, i am confused? esp considering i KNOW Tosto was on stock internals when he did run 10s. so how do you explain that reasoning?
i thougth you team R&J guys could do anything! <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
Tim made that pass once into the tens and smoked his clutch and tore up his 10 bolt! The car will still go ten's on the bottle but he's not going to be able to stay in it the whole time unless he spins the motor to 7000+rpm. And with a stock bottom in GOOD LUCK!
Plus, he is running 28 inch tall tire and did not modify his rear fender wells, on the bottle his tires my grow a lot more and cut into the fender well. I would be careful because at 130+ losing a slick = bad news.
<small>[ March 06, 2003, 10:39 PM: Message edited by: ANIL8U ]</small>
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Bad Habit Bird:
<strong> ok lets say you trap 130 on the spray. With 4.11's and a 28" tire that would put you right at about 6500 ~ 6600 rpms, which is just about perfect. If you want to spin the motor to 7k or higher to cross the traps in 4th then by all means go for it and let us know how well it works out for you. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
Honestly since you already have 4.10's I would just leave them in and see how the car acts at the track. If you absoloutly need to switch then try it and see what happens. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
<small>[ March 06, 2003, 11:07 PM: Message edited by: BADZ ]</small>
<strong> one of my friends buddies in St. Luie has a 12 bolt w/ 4.56, 28" slicks, clutch and 100 shot dry. he loves it and has had no trouble running that setup. yes he shifts into 5th.......so what????? I don't know why it's so hard for someone to grasp the concept of having to shift into 5th. what are u gonna lose 1mph and MAYBE a 1 or 2 hundreths of a second??? he ran a 10.99 on ONLY that setup, stock internals, stock suspention, even stock manifolds. it can be done and it is done. I'm doing it this season, can't wait. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Your wrong, They have never made a pass on the bottle with 456 gears. Plus,you think your going to be able to shift an mn6 with H/C and 150 shot our of the hole? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
And the you can kiss the clutch good by spraying into 5th gear with 28 in tall slicks.
<small>[ March 06, 2003, 12:28 PM: Message edited by: ANIL8U ]</small>
<small>[ March 07, 2003, 01:59 PM: Message edited by: DOC OTIS ]</small>
Just a heads Up!
<strong>...unless he spins the motor to 7000+rpm. And with a stock bottom in GOOD LUCK!
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have been spinning my stock bottom end to 7,000 RPM's for a year now with absolutely ZERO problems...perfect oil pressure with stock 98 oil pump and with ZERO oil consumption <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> , I have 4.56 gears and spray <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> ....quit being so wussy...it is the guys that do what everyone thinks won't work that go the fastest <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" />
I bet your times are great spraying with 456's. All I'm saying is it is way too much gear for the bottle, on the bottle there is no need to spin a stock bottom in to 7000rpm. Your living on borrowed time!
<strong> Yeah, that’s why my 2000 Z mn6 with a cat back, lid , 150 nx kit went 11.18 on nitto's, with 342 gears.
I bet your times are great spraying with 456's. All I'm saying is it is way too much gear for the bottle, on the bottle there is no need to spin a stock bottom in to 7000rpm. Your living on borrowed time! </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">PLENTY of guys reving and spraying into the 7000 rpm range on a stock bottom end for longer than I have AND I never meant my reply as a personal attack...so simmer <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
<img src="http://www.stlhosting.com/upload/Tim230.jpg" alt=" - " />
<strong> What about with a th350 & 410's, 28" tire??????????
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It kind of depends on convertor slippage, and I am aware that you have a new setup being finished but unfortunatly know very little about it <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> all I know is that it will be a bad *** car <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> assuming you cross the traps around lets say 7000 you should mph anywhere from 130~133 once again this can vary with different convertors.
If you get a chance shoot me an email and let me know a little about your new setup <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ March 08, 2003, 05:38 PM: Message edited by: Bad Habit Bird ]</small>
