Tach jumping around after RPM Window Switch install I installed Jegs RPM window switch #40824 This is a digital window switch that also displays RPM. I used the white tach wire from the pcm and set the switch to 4cyl mode The tach jumps around like crazy. The Window Switch displays the correct RPM. I can switch it to 8cyl mode and the tach performs as desired, but the window swich shows half of the correct RPM. I tried boosting the tach signal as suggested in a search with a 1k Ohm resister to 12v+, but this made no difference. Any suggestions? |
Tach signal What kind of vehicle is this? Are you saying if you change the RPM switch setting from 4 cylinder to 8 cylinder that fixes the problem with tachometer?
Originally Posted by brandonppr
(Post 18093293)
get rpm from a coilpack wire and not the tach signal. its the light green wire |
The tach wire is only a couple strands if you used a tap-in style connector it cut the wires.You now do not have a good feed. solder the wires with a good conector and it will fix your issue. |
We always pull signal from a coil or an injector. -Garrett |
Originally Posted by 4wheels
(Post 18099237)
What kind of vehicle is this? Are you saying if you change the RPM switch setting from 4 cylinder to 8 cylinder that fixes the problem with tachometer? Yes, it fixes the problem with the tach, but then the rpm window switch reads the wrong.
Originally Posted by DietCoke
(Post 18099472)
Originally Posted by ShiznityZ28
(Post 18113769)
Originally Posted by NitrousExpress
(Post 18113934)
We always pull signal from a coil or an injector. -Garrett What do I then set my Window Switch to? 4cyl still? |
(Post 18116496)
1998 LS1 Camaro Any coil? just 1? What do I then set my Window Switch to? 4cyl still? |
I was told by Jegs that I need to buy MSD Tach Driver PN 8913 for it to work. |
(Post 18116525)
The harness where the entire bank of coils plugs into the main harness. Pull from the main harness side, light green wire. Keep it set to 4cyl, since you're pulling spark from one bank. |
© 2024 MH Sub I, LLC dba Internet Brands
