How much spray can you run without pulling timing if using a c16 stand alone?
Old 06-23-2014, 08:22 PM
Goosecaddy05's Avatar
Default How much spray can you run without pulling timing if using a c16 stand alone?
i'm thinking of doing a nitrous outlet plate or direct port kit and running a dedicated fuel cell with c16 for when it sprays... i'd like to be able to leave my n/a tune as is... how much can you do safely?
Old 06-24-2014, 01:26 AM
ironhorse583's Avatar
find a retard box..timing tuner or similar..the box only pulls timing when on the spray..i know that doesnt answer ur question..
Old 06-24-2014, 02:08 AM
still that is helpfull, thanks for the info. i know next to nothing about nitrous so i'm exploring my options... can i turn the box on and off with an arming switch inside the cabin as well? i'd like to be able to drive around like normal on my regular n/a tune and then be able to hit a few buttons to get the spay working if i get the itch
Old 06-24-2014, 08:41 AM
brandon@nitrousoutlet's Avatar
Yes you can do that. We offer the LNC-2000 and you can wire it into the main system activation that way the timing is only pulled when the nitrous system is on.
Old 06-24-2014, 09:11 AM
WE TODD DID's Avatar
None. Must adjust timing accordingly
Old 06-24-2014, 05:10 PM
red fury's Avatar
Run a dry kit. Once it is tuned you get what you want, optimal n/a tune all the time, when you spray optimal N2O tune.
Old 06-24-2014, 06:18 PM
i'm not sure about running a dry kit... i've heard those are the easiest way to melt things
Old 06-25-2014, 12:16 PM
red fury's Avatar
Nah, that is BS. It is all in the tuners ability. I ran dry for 8 years on different cams and heads with the stock bottom end. Any were from 125 to 175 shot. Pushed well over 1000 pounds of N20 through that motor in that time period. Just about finished with new motor, still going to run dry kit too. Nothing wrong with a wet kit though.
Old 06-25-2014, 03:13 PM
Dynospeed's Avatar
It's different on every combo and how agressive your na tune is. You can normally tune it with a standalone to be able to run 100-125 shot while only giving up 8-15whp na. I hope that makes sense.
Quick Reply: How much spray can you run without pulling timing if using a c16 stand alone?
