N/A tune is spot on... Do I need a nitrous tune?
Or is pulling timing with the lingenfelter unit ok?
Wanted to start with a 100 shot, and pulling 4 degrees on top my NA tune.
Do you know how much timing your running NA? As long as the nitrous is wired correctly and the noids are in good working order pull 4-5 degrees. I would alway pull a extra 1 or 2 on the first test hit an then you can always put it back in. Also make sure you have good bottle pressure. We recently had a car come in that the customer wired and installed his own kit and said the nitrous felt funny. Come to find out he had a crappy filled bottle.
