digital msd window switch settings hello I was wondering if someone can answer a few questions I am using a digital msd window switch P/N 8969 which right now I have it set to the 8cyl mode what is the difference between the 3 settings? is it bad to have it on 8cyl mode? I have sprayed in this mode seems to be working ok. this is on a 00 trans am by the way. is it have to be a specific setting? any input would be appreciated. thanks |
If it is not on the correct "multiplier" the RPM's won't read correctly and the window switch won't work as it is set. The different modes just change the multipliers. Just make sure it matches what your tach is reading. -Garrett |
you have to set it in 4cylinder mode thats what I had to do with mine work good with my electric shifter with glide |
Mine gets signal from the PCM and it's set on 4cyl mode. Been working fine for over a year. |
© 2024 MH Sub I, LLC dba Internet Brands
