for those with the nitrous outlet fast 102 dual stage bracket
What did you use for gasket material between the TB & the bracket?
The fast TB is just machined back, plate has no gasket...
Wish I would have noticed the lack of throttle cable provisions in the pic. Now I have to get this thing trimmed down to clear.
We designed that bracket to be used with a plate system. Our dual stage 102 plate specifically. I've never set one up with a cable driven throttle body actually. As far as sealing it, I would recommend going to a parts store and getting some gasket material and cutting one out for it.
Does the 102 dual stage plate have gaskets on both sides then? My old 92 plate only had one side, which is why I was curious.
