Maximizer 4 and PCM pinout question I am trying to confirm if I got the right pinout/wires for the max 4 nitrous controller. Red PCM connector VSS pin #55 (green/white) wire Blue PCM connector TPS pin #12 (dark blue) wire Tach pin #35 (white) wire This is for a 98 Camaro PCM. Thanks |
#55 (DK GRN/WHT) should be the VSS output signal on the Red Connector C1 #12 (DK BLU) Should be TPS on the blue connector C2 #35 (WHT) Is your Tach signal on the Blue connector C2 Just make sure its a 98 pcm and harness because 99-02 is completely different. |
Originally Posted by Nilla
(Post 18875753)
#55 (DK GRN/WHT) should be the VSS output signal on the Red Connector C1 #12 (DK BLU) Should be TPS on the blue connector C2 #35 (WHT) Is your Tach signal on the Blue connector C2 Just make sure its a 98 pcm and harness because 99-02 is completely different. Again I really appreciate your help :cheers: |
Glad you got it sorted out. Let us know if you come up with anymore questions! -Garrett |
Originally Posted by NitrousExpress
(Post 18877833)
Glad you got it sorted out. Let us know if you come up with anymore questions! -Garrett I also appreciate all the help that you guys gave me pre/post my purchase. Especially Chris. Highly recommend you guys |
Your very welcome and we appreciate the kind words! -Chris |
© 2024 MH Sub I, LLC dba Internet Brands
