Super noob questions, new to the ls family...
I'm an ex 5.0 Mustang guy so when I wanted to pull timing I just turned the distributor. This is my first ls style car and first time messing with a car with a computer so I have been wondering about some things-
I'm going to have the car tuned at Frost with nitrous. Looking for about a 300 shot. How do I "tune" that at the track for conditions? I'll probably be using an NOS mini controller unless I upgrade before then. Would i just use that to dial in the hit on the track? Obviously I'm fairly new to this, I have only used simple kits with lower hits and even that was quite some years ago and limited use even then.
Pulling the timing on a LS motor is pretty simple. It can be done either though a tune, or a timing controller like the Lingenfelter LNC-2000. Personally, I like the LNC-2000 because with it, you don't necessarily have to run different tunes for motor and nitrous. The Mini is just a basic progressive controller, and will only determine your RPM window and the ramp used, and will have little effect on the overall tune of the nitrous system. If you're new to using nitrous on the LS or if it's been a while since you used nitrous, start off at a smaller shot than 300 to get a good grasp on the tuning aspects of it.
Fueling will be done by jets and tuning it in from reading plugs and AFR. For timing the best option is the Lingenfelter LNC-2000. AJ at Nitrous Outlet can hook you up with one and get you squared away on getting it dialed in.
Well I realize that 300 is hefty but I thought since i was going to pay to have it tuned that they would deal with that. I just know that everyday and every track is different so I was wondering how I would do smaller adjustments at the track. I wouldn't want to spend $600 to have it tuned with say a 100 shot then keep paying that same $600, not to mention the time involved, to work my way up to where I want to be. I'm actually looking at going higher as the car allows. Is my thinking off here or will the LNC-200 allow me to do what I need to do?
And that's the other thing, I don't want to be pulling plugs after every run, what a pita. I'm looking at getting a data logger instead. That would work right?
Data logging and reading plugs is NOT the same thing. Get a good wideband and a Good Fuel Pressure Guage. AEM and Innovate make good widebands. Keep an eye on your afr. af far as plugs its part of the game. You need to check them when tuning. Do a pull to redline and kill the motor pull plugs and check them. on a big shot car you need to be changing plugs out regularly anyways.
No. I wouldnt rely on them anyways. A big shot car needs to be setup if you want it to live. and Fuel Pressure and AFR are important. Reading the plugs helps confirm what the wideband is telling you along with the timing. But hey its YOUR car. You do you.
This is good news, I'll be getting one for sure. I's this something I should have before getting it tuned or it doesn't matter?
Ya I get that, I want it to live! I'm here asking for advice from people that know, I have no problem admitting when I don't know something. I appreciate your advice, just don't mistake my questions for arrogance.
Correct. Also Id find a good dyno tuner in your area.. No offense to FROST but nitrous is not something i would mail order tune if thats what you were going to be doing.
Very true, nitrous is something you want to get tuned in on the dyno, then do fine adjustments at the track. Datalogging is a great tool, but to know what's really going on inside each cylinder you need to pull the plugs. It'll give you important information such as how your timing and fueling is doing, and will also let you know if you're getting any detonation or other problems. You want to get the LNC-2000 before you get the car tuned, because depending on how much timing the tuner puts in it will determined how much you need to pull for a given shot of nitrous. Even if someone else is getting your tune in. you still want to start small with nitrous- after all, depending on weather conditions and other factors, you'll be the one adjusting the timing after pulling your plugs. Getting a good grasp on the tuning aspect will help you get all you can out of your car, and also recognize when things aren't going right.
Ls1tech & Truck Sponsor
http://www.lingenfelter.com/mm5/merc...3#.VipZ1ytyKHQ
This sounds like the option for you. You can pull static timing in HP tuners, it is computer software for the LS platform, but you cant adjust timing on the fly with it, like you can with the LNC-2000.
AFR gauges are great for tuning nitrous and getting everything dialed in, as well as keeping a constant eye on things, however, reading spark plugs is the most reliable tuning tool for nitrous.
If you are going to be running a 300hp shot, you are going to have to pull the plugs at some point to understand how the engine is running on each cylinder, as an AFR gauge only gives you an overall reading from one bank, instead of reading each individual cylinder's heat and fueling from reading spark plugs.
Just my .02$, OP please let me know if you have any questions.
-Garrett
-Garrett
Great information here guys, thanks for clearing that up for me. I'm sure I'll have other questions but those were the ones that really had me wondering.
Still reading plugs... Damn it I thought that with my time away from this we would have gotten away from that. It is what it is...
I have heard good things about Frost. I'm near them, they would be doing a dyno tune. No mail order. Are they good or no? I was going to take the car back to Tick Performance, they did the cage. It's farther but doable. Frost is only an hour away but if the nod goes to Tick over them I'll make the drive.
