What's it take to go From 10.00 to 9.50s 1/4
Currently running 10.003 @135mph with a 1.4 60ft on a 200 shot at 3400 race weight how much more nitrous would I need to run 9.50s I know I need to better the 60ft and I just put a sux2bu ram air in on the car mite help a bit
It's a 6.0 forged bottom built to hold 300+ shot
I have a 4l60 and its shifting into 4th before the end of the 1/4 mile with the 200 hit I mite need to switch to 28 tall tire then huh I'm currently running a 275/50/15 out back do you guys think the 28 will gain any? Or just leave the 26 my goal with it is to be a bad *** and as fast as possible street strip car I would really like to run mid 9s when it's all set and done ***** out
The drag bar is the first mod I wish I would have put on my car. Took the 60' from 1.50 to 1.35 on nitrous. My car was heavy also. Around 3500# with me in it. You should see 9.70s on the 200 shot. A 300 hit would get you to .50s easy.
more tire def help. mine is a ls3 c6 with 2.56 gear and 6l80. with 28x11.5 qtp. i was shifting to 4th with a 26. i figured it would 60 slower with a big tire but get that shift out. it gained .05-.07 on the 60 and knocked down my et about .2 . running 9.73@143 with a 1.43 60'
Well guys I went to the track last nite and made one motor pass picked .3 tenths and 4mph and bettered the 60ft by .1 this was after adding a umi drag bar umi k member and sux2bu ram air we also had better weather
Turned the kit on with a 200 and disintegrated the 10 bolt I went 1.4 60ft 10.00 @135 last time out guess it wasn't having it tonight
