New to nitrous, have a few questions regarding my set up.. - Page 2 - LS1TECH - Camaro and Firebird Forum Discussion
Go Back  LS1TECH - Camaro and Firebird Forum Discussion > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Nitrous Oxide
Reload this Page >
Notices
Old 01-07-2018, 09:04 AM
HCI2000SS's Avatar
Like I was saying about the automatic opener you really don't need one. I would put that last on my list. I never had any issues over many years of use just opening the bottle when taking the car out, then shutting it when I come home
HCI2000SS is offline
Old 01-07-2018, 09:17 AM
I have the winmax. Gear lockout works off of reaching a user specified max rpm and then a user specified rpm drop to tell the unit that a shift occurred. It doesn't know what gear you're in, it's just looking for a "shift" that you specify once the system is armed. I spray 150 all at once on an SS4000, but don't spray through the shifts. Stock rebuild 4l60e with transgo shift kit.
Hardtop Brian is offline
Old 01-07-2018, 09:45 AM
RollinSScamaro's Avatar
Thanks for explaining the winmax! Very helpful! Does the progressive do the same thing other than you have the ramping option as well? I could see the ramping being nice at the track potentially to avoid blowing tires off. So you spray the 150 in 2nd? Glad to see the ss4000 and trans are holding up since that's how I'll be running as well. I'd launch out of 1st, but my 10 bolt would be toast lol. I've heard it's better to have it shut off a few hundred rpms before each shift and reactivate after the shift so I plan to do the same. You run an LNC2000 as well?
RollinSScamaro is offline
Old 01-07-2018, 09:51 AM
I agree.. I would like one for convenience though .. if I find one used I'll prob get it, if not I'll go without. You have a gauge mounted in your car right? Is it digital or analog? I've seen the digital kits for $110+ and NX has a remote mount kit for $300+.. I was thinking it would be a simple $30 gauge with a line running from gauge to the tank . Didn't think it would be so costly to have one in the front of the car lol.. maybe with the adjustable bottle pressure sensor on the heater it isnt necessary to have eyes on it?
Old 01-07-2018, 10:03 AM
HCI2000SS's Avatar
Originally Posted by RollinSScamaro View Post
I agree.. I would like one though for convenience.. if I find one used I'll prob get it, if not I'll go without. You have a gauge mounted in your car right? Is it digital or analog? I've seen the digital kits for $110+ and NX has a remote mount kit for $300+.. I was thinking it would be a simple $30 gauge with a line running from gauge to the tank . Didn't think it would be so costly to have one in the front of the car lol.. maybe with the adjustable bottle pressure sensor on the heater it isnt necessary to have eyes on it?
Mine is just a mechanical gauge and yes it's mounted in the a-pillar. Yeah the cost of some of this stuff is a bit crazy and simply not necessary when spraying smaller shots. My bottle heater is pressure regulated, but to be honest I like being able to read the pressure regardless. Just peace of mind. You could even use that cubby hole for a gauge as well, since you already have the 3 pod pillar now. Did you get that kit yet?
Old 01-07-2018, 10:10 AM
HCI2000SS- Sounds like you are of the school, "Better to know, than not to know". I agree with it! Beats being paranoid, because "Paranoia WILL destroy ya!" lol
G Atsma is offline
Old 01-07-2018, 10:13 AM
I will have to look around and see.. worst case glowshift sells a digital gauge for $110 with everything id need, but maybe I can find a cheaper option. I'd like to be able to see it as well just so I know everything is good. I got the kit Friday! Everything looks good just no bottle clamps, activation, or WOT switch. Basic plate kit, solenoids, 10 lb bottle, all of the jets, and lines. It's an NX bottle which is kind of weird, but they all have the same purpose so not overly concerned. According to the schematics I may need to purchase a $20 Relay and harness as well.
Old 01-07-2018, 10:17 AM
HCI2000SS's Avatar
You are exactly right lol. Especially when dealing with a power adder like nitrous.
Old 01-07-2018, 10:22 AM
HCI2000SS's Avatar
A NX bottle but the rest is Nitrous Outlet? I'd be curious why that is, but like you said it shouldn't matter. Also most kits come with a WOT switch so that's a bit odd, but no biggy since it's not expensive
Old 01-07-2018, 10:27 AM
Yea i thought it was weird.. I should have asked, but never thought it would be different lol. Yea the brand new kit would have come with WOT and activation, but I may use a nos mini progressive of some sort of window switch regardless which will cover the WOT and my switch panel will cover the activation. The heaters come with clamps as well so I will end up with everything I need at some point.
Old 01-07-2018, 10:41 AM
HCI2000SS's Avatar
Yep I hear ya. Although not necessary it would be kind of nice to have these options all tied into one switch panel. Nice thing about nitrous is you can just sort of piece it together after all the basic important stuff
Old 01-07-2018, 11:04 AM
  #32
Yea the only issue I'd have not running a window switch is spraying through the shifts which I don't want to do to make sure my trans can handle it.. as a 6 speed does it stay activated during your shifts?
Old 01-07-2018, 11:12 AM
  #33
HCI2000SS's Avatar
Yeah I wouldn't wanna spray through the shifts either. For me no it doesn't stay activated since I am letting up on the gas when shifting. No powershfting for me lol. So you gonna mount that kit up when it gets a bit warmer out?
Old 01-07-2018, 12:08 PM
  #34
That makes sense.. I may not get it hooked up this year. Might be next winters project.. I'm just going to piece everything together for now when there are sales or good used parts. I'm trying to keep the projects light this year so I can get it out sooner and enjoy it since I only get to drive it on weekends now.
Old 01-07-2018, 12:22 PM
  #35
HCI2000SS's Avatar
Yep I get that. I only put on 900 miles this last season. I need to start enjoying it more, or consider another hobby lol
Old 01-07-2018, 02:26 PM
  #36
A good progressive is well worth the money. It comes with all safety features you want in one device. Since I have hptuners I'm a fan of the iat tricker or traction control method for pulling timing. I believe his name is 5.7stroker, check out his thread for install and some good info. Sounds like you already shop the classifieds pretty good so by the time your ready for install you should be able to find some good deals on what you need yet.
tug686spd is online now
Old 01-07-2018, 04:47 PM
  #37
baronsmith98's Avatar
RollinSScamaro I am selling a used NX Maximizer 4 progressive controller for $300 shipped if you are interested. It's a really great controller. Can ramp in nitrous by time, gear, throttle position, or speed and has a built in window switch. Pm me if you want it.
baronsmith98 is offline
Old 01-07-2018, 05:18 PM
  #38
HCI2000SS's Avatar
That Maximizer 4 is really cool. I almost bought one at one point
Old 01-12-2018, 05:12 PM
  #39
5.7stroker's Avatar
Thanks for the replies. On yanks website they claim the SS series is good for nitrous application, but I've heard of some saying 150 shots were blowing through theirs.. the most I'll honestly ever run would be 150 and will probably start at 100..
Are there any advantages of using the plate kit? They do look nice and seem to make it a clean install under the hood.. I know there are a lot of accessories with nitrous that add up quick.. seems like you could drop 1500-1800 easily with a 92 plate kit, heater, remote opener, gauge, switches, lingenfelter modules, etc. What have you guys seen for total cost?
Another question I meant to ask was regarding piston gap.. will stock gap be okay for occasional 150 and below shots or should I have the machine shop gap them?
See post number 6 here: https://ls1tech.com/forums/nitrous-o...ous-world.html
and post #57 here: https://ls1tech.com/forums/racer-s-l...our-car-3.html
Also check out this new product: http://www.nitrousoutlet.com/electro...sors-5166.html
Here's the links for my install and the wiring diagram to pull timing using HP tuners.
https://ls1tech.com/forums/nitrous-o...l#post19366061
https://ls1tech.com/forums/nitrous-o...-see-here.html
5.7stroker is offline
Old 01-12-2018, 05:55 PM
  #40
Damn that's a ton of great info all tied together. I love the part number references! I've been trying to make sense of a few accessories and how to tie them all in and I think this will help. I appreciate you taking the time to piece multiple threads together into 1 post. I'm pretty pumped to see what n20 does for my car.
So far I've purchased these parts:
92mm plate kit with 10lb bottle
Purge kit
Ash tray switch panel
Used nitrous outlet window switch w/ gear lock out
Quick Reply: New to nitrous, have a few questions regarding my set up..
Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
